1990 Nissan 240sx SR20det
I have a 1990 240sx for sale, looking to get 6200 obo
can tex me at 616 843-1306 for more pics or email me. In 2009 the motor was pulled and had installed the full seal kit including valve seals front and rear main seals and all seals inbetween. All of the covers and pans were resealed using Hondabond silicon. Also installed new timing chain, guides, and tensioner. There have only been 9000 miles put on it since. Car is great mechanically but has a couple dents and and couple spots with rust and the paint is fading. Have over $13,000 in parts, it runs great doesn't burn or leak any oil. Use royal purple full synthetic oil, and did a tune up in April. Engine and Transmission: Sr20det red top, ECU, 5 speed transmission 2 1/4 Hotpipe w/HKS SSQV Blow off valve Greddy R SPL Front Mount Intercooler Greddy Profec Spec B II Boost Controller Walboro 255 Fuel Pump 3'' Stainless Steel test pipe Greddy 3'' Downpipe Nismo adjustable fuel pressure regulator KOYO Radiator 3'' Core Nismo Thermastat Heater Hose and radiator kit SR20DET Greddy Oil Pan ACT HD Clutch Kit B&M Short Shifter New Timing Chain, Tensioner, gasket/seals, hardware installed 6/09 Aluminum oil catch w/breather, hoses and fittings Rebuild of T25 turbo done 4/08 Stance Water neck adapter DIF Dual fan Controller S14 Oil Strainer Greddy Speed Limiter Cut Flex-A-Lite Twin fan 2500 cfm Megan Racing Exhaust Manifold Megan Racing Turbo Extension Nismo Engine/transmission mounts Techanfit SS Clutch line Apexi GT Spec Exhaust 3'' Nissan Clutch Master Cylinder Suspension, Brakes, Wheels: JIC FLTA-1 5 way adjustable suspension Whiteline adjustable sway bars SPL v2 front tension rods SPL Solid rear subframe aluminum bushings Nissan S15 HLSD Power Slot Rotors front and rear Hawk HPS brake pads Technafit SS brake lines front and rear 5zigen FN01RC 17x7, 17x8 4x114 +35 wheels Brand New Kuhmo Ecsta Tires on the front Interior: Defi Blue Racer Digital gauges: Boost, oil pressure, water temp Nismo shift knob Pioneer Cd player with ipod hookup, and Hd radio Polk Audio speakers Python alarm system Last edited by street-racer18; 08-06-2013 at 08:59 PM.. |
Will consider partial trade for a 5 speed daily driver plus $3000. More pics can be seen at http://holland.craigslist.org/cto/3983791861.html
sr20 240 s13 sr20det |
