Old 05-07-2013, 09:04 PM   #1
onevia drift
onevia drift's Avatar
Trader Rating: (18)
onevia drift is an unknown quantity at this point
Feedback Score: 18 reviews
Full KA24DE swap
Jake Shaw
Fresno CA
559-940-3045
Buying options.
-full swap including trans, and 5spd conversion stuff...$1000
*includes turbo mani, fmic core, 3" down pipe.
-full swap minus conversion parts...........…................$850
-assembled long block, harness, ecu, no trans............$750
-motor/accessories only, no harness, ecu, trans..........$650
Im selling ONLY because I found a badass deal on something else
History:
The motor originally came out of a '94 vert. The previous owner was an elderly woman. The odo read 175k....
She said it had been rebuilt recently, and ran rough ever since, but didnt have any paperwork.
When it was bought it was running rough. I did a compression check and got really low numbers.... like 60psi.
I tore the motor apart and checked everything.. It looked to be super fresh.
Cylinder walls still had perfect honing, the block was oil/sludge free, freeze plugs looked brand new, the timing chains were new, the tensioners were new, and I drained the oil through a fine mesh and a large magnet... I didn't get a single shred of anything metallic!
It was excellent... except for the exhaust cam was off by 2 teeth and slightly bent every exhaust valve.
I replaced the head with a known good one (rebuilt myself a few years ago for a car that had been sold)
I replaced the main seals/crank seals and oil pump gears with new ones just because I had them lying around, as we'll as the IACV.
Now it runs perfect. I have been daily driving the car for almost 2 months. It hasn't leaked a drop of oil that I've noticed (garage kept).
What's included:
-motor
-trans
-flywheel
-oem clutch
-wiring harness
-ecu (5spd or auto, I have both)
-exhaust manifold
-down pipe
-motor mounts
-radiator hoses
-fan shroud
-oem egr stuff (canister, the stupid assembly by the passenger wheel well)
-intake tube
-air filter box
-intake coupler
I CAN ALSO INCLUDE 5spd CONVERSION PARTS TOO!!
-driveshaft
-clutch pedal
-clutch hard line with dampener
-bnib clutch master
-bnib clutch slave
-bnib throw out bearing
Pros:
1300 mi on:
-rebuilt head
-new head gasket
-new valve cover gaskets
-new front main seal
-new rear main seal
-new timing chains
-new hydraulic chain tensioners
-new oil pump gears
-new iacv
-new timing chains
-new spark plug wires
-new distributor rotor/cap
-new water pump
*everything above has 1300~ish mi in use as of right now
Cons:
Vacuum delete under intake manifold
No egr tube.
I will include intake tube, filter box, intake coupler, alternator,
a ram horn style turbo mani, fmic core, and 3" downpipe.
It has always been an automatic motor. It currently still is.
I have a 5spd trans, oem clutch and flywheel and conversion parts if needed.
Im trying to sell it as a full swap with harness, ecu, and trans.
onevia drift is offline   Reply With Quote
Old 05-07-2013, 09:11 PM   #2
onevia drift
Trader Rating: (18)
Vid sounds super shitty. I have a hole in my cat from speedbumps in my apt complex :/
http://static.photobucket.com/player...ps833d64e3.mp4
Old 05-07-2013, 09:23 PM   #3
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Got a video of it running? Sounds nice.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 05-07-2013, 09:55 PM   #4
Giiio
Giiio is an unknown quantity at this point
Wish you were a lot closer. I'm lookimg for a full swap
Giiio is offline   Reply With Quote
Old 05-07-2013, 10:19 PM   #5
onevia drift
Trader Rating: (18)
Vid is loading to photobucket.
Im willing to meet half way within reasonable distance.
I might be able to ship for super cheap too. I work at Trail Gear and we ship huge/awkward stiff all the time. Im getting a quote tomorow for a guy in Minnesota lol
Old 05-08-2013, 06:11 PM   #6
onevia drift
Trader Rating: (18)
Buuummmmp.
I quoted a guy $198 shipped to Minnesota..
I can ship with a very reasonable price through work.
Old 05-08-2013, 06:14 PM   #7
Giiio
Pm price shipped to 91744
Old 05-10-2013, 08:42 PM   #8
luiss14
luiss14 is an unknown quantity at this point
plz pm me if u are willing to sell the engine harness i need one for my 95 s14 5spd also the ecu
Where Dey Do Dat At
luiss14 is offline   Reply With Quote
Old 05-10-2013, 10:09 PM   #9
onevia drift
Trader Rating: (18)
Motor, trans, ecu, harness os soldddd
dohc, ka24de, ka24e, s13, sohc
