07-30-2008, 01:12 PM | #1 |
Oxygen / 02 Sensor doesn't register?
My car has been sluggish lately with slight bogging/hesitation problems. I've checked compression, spark, and fuel with no problems there. Today I disconnected my O2 sensor to see if it runs any different in open loop and absolutely nothing changed. My check engine light didn't even go on. So now what?
07-30-2008, 01:15 PM | #2 |
a bad o2 sensor will not cause drivability problems. check for vacuum leaks. you chould have a bad tps. there are so many factors. we need more detailed information.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
07-30-2008, 01:31 PM | #3 |
07-30-2008, 01:48 PM | #4 |
Actually, a bad o2 sensor will make the car run pig rich, is your car modified any? Best thing to do would be disconnect the o2 from the harness, and use a multimeter to see what the voltage is reading if any.
07-30-2008, 02:04 PM | #5 |
07-30-2008, 02:09 PM | #6 |
haha, i have a redtop sr. obd 1 cars dont use the full capability of the o2 sensor. the o2 just helps out at cruise and idle. i dont even have an o2 sensor wire on my car and it runs fine. it will run a bit rich but nothing noticeable unless you're checking your mileage every day. for you i would check vacuum leaks and maybe your maf sensor. those are usually the culprits. and while you're at it, check the ohms of the coolant temp sensor.
07-30-2008, 04:20 PM | #7 |
My car runs the same whether I have the o2 sensor plugged in or not. Idles perfectly and cruises no problem. All my grounds are good. My maf sensor checks out perfect as well as my tps. Car doesn't have any modifications other than emissions removal and a cooler thermostat. I can check the coolant temp sensor but I doubt that's the problem. My main problem is slow acceleration which doesn't seem to be O2 sensor related; however, I'm slightly shocked that unplugging the o2 sensor has no effect on anything.
07-30-2008, 04:24 PM | #8 | |
I am a firm believer in NOT having a cooler thermostat. Emissions removal will affect drivability |
07-30-2008, 05:43 PM | #10 | |
Can I just stop you there; Please tell my why Nissan placed an o2 sensor anywhere in, or outside of the vehicle? If it is just meant to be removed like fresh wrapping paper on that new lego set, then I will remove .03lbs of weight off the manifold. The OP didnt ask if he should leave the o2 off.....IMO its one of the more important sensors on the car. this is if you meant to OP can leave his O2 sensor off.... |
07-30-2008, 05:58 PM | #12 |
07-30-2008, 07:26 PM | #13 |
I bought the car without the emissions equipment installed and I've never had a problem, ever. Same goes for the thermostat.
I also agree that the o2 is one of the more important sensors in the vehicle which is why I'm confused as to why it doesn't make a difference whether it's plug in or not on my particular vehicle. If it's not registering with the computer I'd like to know why as it could effect my fuel efficiency as well as acceleration. The motor is not running at the same efficiency as it was new and it's important for the computer to have the feedback necessary to make the appropriate adjustments. Is there a way to find if the o2 sensor is sending any kind of signal to the computer? I can buy a new one but it won't matter if the ecu isn't receiving anything. Also, shouldn't the check engine light come on when I unplug the sensor? |
07-30-2008, 11:58 PM | #15 |
Yea I meant that he can leave his O2 sensor off, its pretty much for emissions. Yes it does help the car from running so rich, as a pose to not running an O2 sensor. I've ran my SR without an O2 sensor and when I plugged one in, I could barely tell the difference, if any. I'm just trying to isolate as many things that might not be the cause of his issue.
To the OP, keep us updated if you find the solution for future reference |
07-31-2008, 06:49 AM | #18 |
07-31-2008, 10:11 AM | #19 |
I found a small tear in my intake after the maf and taped it up. That solved the stumbling/hesitation problem but the car still feels sluggish compared to another 240sx I drove a couple weeks ago.
My car seems to have the same acceleration at 3k rpms as it does at 5k. It also seems to accelerate the same whether it's at 50% throttle or 100%. I'll go through the fuel system to make sure I have plenty of fuel pressure, clean injectors and fuel filter. I questioned the o2 sensor initially because the slight backfiring between shifts indicates to me it could be running slightly rich. I am surprised to find such a discrepancy between people regarding the o2 sensor... some posts note their cars running crazy rich blowing smoke everywhere and others not noticing a difference at all. Even if it means getting one or two more mpg on the highway, I'd prefer to know whether it's working correctly or not. Last edited by jharper; 07-31-2008 at 01:31 PM.. |
08-05-2008, 11:00 PM | #20 | |
now to check the 02 disconnect the harness and use a volt meter to place the lead on the signal and another on a good ground. now check voltage if its around .02 its running lean and it if it goes to .08 its running rich. if it dosent read jack it dosent have good ground from the manifold duh or the 02 is just no good or contaminted. now to check if the computer is reciveng the signal back probe on the ecu put a lead on the signal wire at the ecu just careful not to pierece the insulation. now wat ever you read thats wat the computer is reading. just make sure to discharge your self before handling the ecu. now for all of yall who think im a dumbass for writing this go ahead talk all your shit cause im just here to help out. |
