07-24-2018, 06:27 PM | #1 |
DIY S14 Electric Fan Install
DIY Electric Fan Installation for the Cooling System
Preface This will be my second DIY. There are plenty of instructions covering this topic, but I will be showing what I did to archive this, and why. Four years ago when I bought my '96 S14 the prior owner had wired both the headlight positive and electric fan positive together to a switch on the middle console. It had no clutch fan, just was using the stock AC fan. During the first year of owning the car I reverted the headlights back to stock wiring, then re-did the wiring for the fan switch. Instead of the positive running to the switch I ran the positive to a relay which I taped into the AC fan power (12v with ignition acc/on/start), then ran the ground to the switch. The next two years there was times I kept overheating the car from forgetting to turn on the switch. Then last year I decided no more, I bought a neck fitting for the radiator hose and a water temperature sensor. And got it working properly. This DIY will be how I did it. Some people prefer a controller, I prefer to get things done cheap, easily, and efficient. Parts/Tools
Warnings
Images The AC fan I re-used. The radiator hose neck adapter (36mm) with the thermostat switch, if you noticed I opted to cut my radiator hose and then connect the hose neck. Make sure you don't have any leaks here. The relay with my messy wiring in the engine fuse box. Wiring
Steps
That's it, it's a straight forward procedure. After I did this, I ended up doing the same thing to my MK3 Supra (since my 2JZ was missing the clutch fan as well) but using two slim fans. Any suggestions, advice, edits, etc, feel free to reply on here or message me. If some reason the images go down, contact me and I'll try to get them back up. Once this is solid I can try to get it to a PDF. |
07-24-2018, 07:39 PM | #2 |
That's meant to be an auxiliary fan only, not a main fan. Not only is it too little to provide enough air when pushing the car, but it lacks the proper ducting to take advantage of the entire radiator.
Altima radiators I believe is what most use. A dual fan, tough built and efficient radiator fan assembly with the right ducting for a 240 radiator size.
Tuners are big bullies Last edited by feito; 07-24-2018 at 08:14 PM.. |
07-24-2018, 08:49 PM | #3 | |
But as a note; as long as this "auxiliary" fan runs I don't have overheating issues, the needle stays slightly under the middle mark. That's even with during the heat wave that just went through. But I'm still running a stock KA24DE. I'm going to update my wiring later on to support when the AC is on. |
07-24-2018, 08:01 PM | #4 |
^This. Upgrade to Altima fans. They are not that expensive and they fit very nice over the 240sx radiators with minimal modifications.They move A TON of air. I can feel the air moving through the outside of the grill when they are on, no joke lol.
I wired each fan to it's own relay which were both triggered with the stock a/c fan's relay circuit. Using the factory ECU, the a/c fan circuit was designed to kick on when coolant temp is around 95*C. I do believe this can be customized with most standalone ECU's. I do plan on adding a thermoswitch like you did so the fans will kick on a little sooner around 80-85*C and a manual override switch in the cabin somewhere. |
07-24-2018, 10:38 PM | #6 |
As I mentioned in my original post, I worked with what I had. I did not have the stock clutch fan and shroud. When I bought the car it didn't had any of that, nor was I able to source it.
Tags |
240sx, electric fan, radiator, s14 |
