Old 05-19-2021, 01:27 AM   #1
rustable15
rustable15 is an unknown quantity at this point
RB RB engine with multiple restrictors
I have an rb25 and plan on putting in 2 1.5mm restrictors into the block but is it possible to go with a smaller restrictor in the future once I go to a different oil pump?
rustable15 is offline   Reply With Quote
Old 05-19-2021, 07:55 AM   #2
PoorMans180SX
PoorMans180SX's Avatar
Generally you peen the hole a bit so the restrictor can't come out. You're probably better off installing them once. Why would you change them when going to a different pump? Does the new pump generate more pressure? If so, you can simulate it by shimming the relief spring.
Old 05-19-2021, 12:22 PM   #3
jr_ss
There are various pumps that increase oil volume over others.
http://www.skylife4ever.com/2014/08/...-pump.html?m=1
There is a chart out there that recommends specific restrictors with specific pumps based on your setup.
Old 05-27-2021, 07:50 PM   #4
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
What would be considered too much pressure?
I have an N1 pump with spool import gears and 1 oil restrictor blocked. the other is left stock.
It's been awhile but I believe I was seeing 7-9bar oil pressure on a cold start and it gets over 7bar on WOT if I remember correctly, it's been a few years.
smoked240 is offline   Reply With Quote
Old 05-28-2021, 06:00 AM   #5
PoorMans180SX
That sounds like good pressure for an RB to me.
Old 05-28-2021, 10:01 PM   #6
smoked240
Good to know! Remembering now I also went to the +.001 bearings on rods and mains.
