02-19-2019, 11:42 AM | #1 |
No Spark Plug - Silvia 200sx
Hello friends!
My name is Fernando from Argentina, I have a Nissan Silvia S14 Zenki SR20DET LHD. I have a big problem! The engine not start and I dont have spark. I made this: 1. Check the ignition relay = WAS OK (next to the ECU motor, passenger side) 2. Check the ignition fuse 7.5A = WAS OK (fuse box, near to clutch pedal) 3. Continuity between fuse 2 and pin 43 of the ECU = WAS OK 4. I have 12 volts on the blue wire coils (I have new colis and new spark plugs) 5. I checked the injectors and CAS = WAS OK I'm desperate because I do not know what else I can check. Someone can help me? Last edited by ferlepo; 02-23-2019 at 12:18 PM.. |
02-22-2019, 12:30 PM | #3 | |
Yes! I just installed more than 4 ground. (intake manifold, head, engine block and behind the fuse box). I dont have +12v on the ECU. (ECM) PIN 49, 59 and 109 must have 12v. but I dont have it. I checked everything. I do not know what else I can check. I checked every relay and fuse. |
02-23-2019, 12:21 PM | #4 | |
But I dont have spark. I checked the pulse injectors with a led light and it's OK (blinking) but I dont know why it does not start the engine. Do you have any new idea? |
02-26-2019, 08:33 AM | #5 |
if your fuses are good but you don't have power to the pins that need power i would try swapping relays with known good ones and if that still doesn't work then check the wire from the fuse to the ecm for damage
02-26-2019, 10:17 AM | #6 | |
Yesterday I remove the CAS sensor, put the switch ON, and I did spin by hand but I cant hear injectors noices. Fuel pump is activated when I spin by hand the CAS sensor. |
