S13 Restoration - A/C question
Currently working on a S13 shell I picked up with a completely intact A/C system. Seller says A/C worked up until the KA got a rod knock then sat for 6-8 months.
My plan was to clean up the shell and move stuff over from my donor car leaving the A/C system intact and sealed...... But as usual my ocd found a couple issues I would like to fix. 1: factory firewall insulation is crumbling and falling down. 2: Painting the engine bay/interior... My Questions for anyone familiar with a/c in these cars are: A: Is a rebuilt A/C ever the same as Factory? B: Do I have to use special tools to empty the system? C: Does someone still carry the O-rings & seals for a 91 240 (could not find anything other than compressor seals) D: what should I replace if I want to completely remove the A/C for Paint and put it back in? |
![]() Join Date: Nov 2010
A/c is easy to restore. YOu will likely want a shop to vent the old system so your not venting to atmosphere.
A: if you are converting to R134a it will never be as cold as R12 but it still is very functional. B: Shop can empty C: Orings are generic and easily sourced at auto parts store. D: Drier/Receiver must be replaced anytime you open the system. It is also advised to replace every o-ring on the connections you take apart.
For as many times as I have had my car apart, I went to 134a. Cheaper to refill and source. I’ve already had it charged a few times over the years from swapping engines and repairing cracked a/c lines.
