Old 11-12-2019, 08:04 AM   #1
saiga488
saiga488 has a little shameless behavior in the past
S13 180SX RHD Master Cylinder Upgrade?
I am wanting to do the Evo 8/9 front brake caliper/rotor upgrade and it appears that most people recommend that I need to upgrade the master cylinder also. I see most people recommend the Z32 1-1/16 BMC. The problem is that all of the master cylinders that I find are all for left hand drive cars. I have a RHD 180sx car so the brake lines are on the opposite side. Any recommendations on which BMC to buy and where to buy it?
saiga488 is offline   Reply With Quote
Old 11-12-2019, 09:06 AM   #2
S14rebuild
https://www.rgsperformance.com/product/bm57_bmc/
30sec google search
Old 11-12-2019, 12:36 PM   #3
Super_OK_S13
Super_OK_S13's Avatar
Super_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud of
I did the z32 brake swap all around and used a 1" bore, for a 95 Nissan pathfinder. 1" bore to go with my manual brake booster. Can't say if they will line up with Factory hard lines, as I am using a chase bays oem relocation kit.. They come in different bore diameter with the ports on the correct side you need it on. Mine is a doorman part #m39976 with the factory nissan looking reservoir.
i paid less than 75$ for a NEW one, not re-manned.
check out this site for BMC size comparison...
https://importnut.net/300zxbrakeswap.htm#MC
Last edited by Super_OK_S13; 11-12-2019 at 02:52 PM.. Reason: bmc part number/year
Super_OK_S13 is offline   Reply With Quote
Old 11-13-2019, 05:44 AM   #4
gaz_moose
gaz_moose is an unknown quantity at this point
having the outlet ports on the 'wrong side' and using banjo fittings will give you more clearance in the engine bay.
gaz_moose is offline   Reply With Quote
Old 11-13-2019, 06:18 AM   #5
Super_OK_S13
On a Lhd Bmc, I tried using the banjo fittings and there was no room for them or else I would have used my LHD BMC.
Old 11-19-2019, 08:53 PM   #6
gaz_moose
just find someone breaking a 300zx on ebay.co.uk or try garage-D in England.
