06-19-2012, 08:05 PM | #1 |
1990 Nissan 240sx Hatch, kit, wheels, coils
Location: Charlotte Contact: PM or Email [email protected] 1990 Nissan 240sx s13 Hatchback $3500obo Clean Title Description: Rebuilt SOHC with 10k-15k probably 180k on chassis odometer works when it wants New distributor New ingnition coil New fuel injectors New fuel pump New plugs New plug wires about 60miles ago Cone style air filter 3" cat back exhaust Testpipe Powered by Max Tension rods Godspeed rear toe arms Godspeed rear upper control arms Godspeed sway bars not installed Megan street coilovers 300zx Brake swap with out ebrake SS Conversion Brake lines 5 lug swap with new ichiba hubs in the rear new bearings up front 60mm studs for the rear XXR 527 18x9.5 +20 225/45/18 front 255/40/18 rear Comes with an extra set of tires in the same size New windshield Grant steering wheel JDM dildo shift knob yo! Un cracked dash!!! Wooo!!!! Kirkey Intermediate Road Race seat Unknown Fiberglass race seat Garret/AIResearch turbo Manual seat belt conversion Autometer water temp gauge wired and installed dont know if its reading right of it the car runs that cold Whatever else I have that is 240 related goes with it. Bad Typical 240sx problems Speedo works when it wants Coolant temp gauge works when it wants have an extra cluster though Cork oil pan gasket was used for rebuild so the oil pan drips no ac No rear interior Use to be red was sprayed white no lock cylinder on ignition will come with two lock cylinders Needs a left front fender No latch for the fuel door has a cold idle issue, after warm runs fine. |
coils, kit, slowered, stance |
