Old 06-06-2011, 07:00 PM   #1
-LSD-
-LSD- is an unknown quantity at this point
KA KA24 no ignition or fuel
Hey guys, any help much appreciated in advance.
A little preview: after rebuilding my engine i dropped it in the car, everything seemed to go well, i deleted all the emissions, ac, and some random useless stuff, i connected all the wiring, checked it 3 times, everything looks good.
I was trying to crank the engine, i heard the fuel pump kicked in, all the lights on the dash came on, but when i started cranking it, nothing happen, starter was working i heard compression in the engine, but it didnt even try to run. i was getting fuel in the rail. but it seems like injectors dont do anything, so as ignition, i checked it and got no spark, which is really confusing to me. the only thing that i could think of is ecu, but i never touched it, it was working perfect befor the rebuilt...
Let me know if u have any ideas what could be the problem, because im so frustrated im about to give up on that car.
-LSD- is offline   Reply With Quote
Old 06-07-2011, 03:12 AM   #2
-LSD-
looks like ppl are not really sure...
ill ask another question...if any can answer that...
since ecu controls injectors and spark, and it based on cam positioning sensor, what if my distributor is 180 out, would that confuse ecu and it wont power up anything?
Old 06-07-2011, 09:08 AM   #3
562s13
562s13 is an unknown quantity at this point
if your distributor is off by even a tooth that would do it. also check your ground wires..
562s13 is offline   Reply With Quote
Old 06-07-2011, 02:59 PM   #4
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
If the dizzy is off by a tooth or whatever your still gonna have fuel and spark. Obviously just not at the right time. Check the ecu for codes. The cas could be bad. If you have another ecu available (sitting around or a buddies) I suggest trying that as well. When I rebuilt my engine the ecu took a shit on me. The only cylinder working was #4.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 06-07-2011, 05:04 PM   #5
-LSD-
wow amaizing, im wondering why shit like that happens, ill try to swap ecus next monday, see whats gonna happen, is it ok if i will use my tuned ecu just for test purposes? if not i can get auto ecu, i think that should work on my 5 speed car.
Old 06-07-2011, 07:49 PM   #6
Pro ViZIon
Pro ViZIon's Avatar
And double check the harness grounds for the motor.
Old 06-08-2011, 01:42 AM   #7
-LSD-
yeah, im pretty sure im missing at least one of them, might be even main that goes to the intake mani, since i relocated the battery in the trunk =/ stupid me
Old 06-08-2011, 02:34 AM   #8
Pro ViZIon
Pro ViZIon's Avatar
Well the engine harness grounds won't have anything to do with the battery. There's on ground on the intake mani by the coolant temp sensors and one on the driver side of the head towards the back.
Old 06-08-2011, 02:52 AM   #9
-LSD-
i know for sure i conected one in the back of a head on the exhaust side, and im pretty sure one that comes out right next to the injectors in the front is connected as well...but im probably missing something else.
