09-04-2022, 01:03 PM | #1 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
Massive S14 Zenki / Kouki Garage Sale - Interior, Exterior, Suspension, Wiring, +more
SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM. LOCATION: Los Angeles, CA PAYMENT OPTIONS: Cash, Paypal Combining all of my S14 items into one thread to keep things simple. S14 Exterior $15 - S14 Zenki/Kouki Turn Signal Housing (lens damaged, LH and RH available) $30 - S14 Zenki/Kouki RH Turn Signal $40 - S14 License Plate Light $75 - S14 Windshield Wiper Cowl Cover $250 - S14 Wingless Trunk $200 - S14 Zenki LH Fender (Mint) $50 - S14 Zenki RH Fender (Dented, but easy repair) $150 - S14 LH Rocker Panel (cut where it meets the quarter panel $250 - S14 Subframe Mounting Studs $25 - S14 Zenki OEM Bumper (trimmed for large FMIC) $200 - S14 Zenki OEM Bumper Support with retainer $50 - S14 Rear Bumper Support (two available) $15 - S14 Rear Bumper Brackets $25 - S14 Rear Factory Tow Hook $75 - S14 RH A-Pillar Exterior Trim $50 - S14 RH Quarter Glass (no trim) $10 - S14 LH or RH Weatherstripping Retainer $75 - S14 LH Door Window $75 - S14 RH Door Window $40 - S14 Rear Glass Lower Finisher Trim $25 - S14 Kouki RH Door Handle $25 - S14 Zenki Hood Prop $50 - S14 Wiper Linkage Arm Set $20 - S14 Windshield Wiper Cowl Metal Cover $30 - S14 Fuel lid door (two available) $50 - S14 SE Trunk Support Bars Interior $20 - S14 Dome Light $15 - S14 Antenna wiring harness $100 - S14 Fuel lid release cable with brackets (fuel lid only, no trunk release on this model) $15 - S14 LH or RH Door Handle Bezel $50 - S14 Rear View Mirror $50 - S14 Cluster Bezel $15 - S14 Throttle Pedal Stopper $25 - S14 Turn Signal/Wiper Stalk Holder / Bracket $40 - S14 Wiper Stalk $35 - S14 RH Kick Panel $100 - S14 Heater Core Box (removed from a '95 Zenki) $30 - S14 Speaker Door Bracket Set $15 - S14 RH Door Speaker Bracket $15 - S14 RH or LH Triangle mirror cover $30 - S14 LH/RH Triangle mirror cover set $20 - S14 Lower Dash / Steering Column bracket (three available) $15 - Steering wheel spacer $10 - black spin knob $30 - S14 RH A-Pillar $75 - S14 B/C Pillar Set $15 - S14 Rear Seat Airbag Module Cover (prevents middle section on seat from sagging) $25 - S14 Rear Seat Striker Bracket $30 - S14 Fuel Pump Sender Cover Suspension/Brakes $100 - S14 Rear Knuckles $30 - S14 Rear Subframe Braces $100 - S14 Brake/Fuel Hard lines (NON ABS) $100 - S14 Brake/Fuel Hard lines (ABS) $400 - S14 GP Sports Coilovers (1 Front has a bent shaft. Straighten it out and run it on a cheap drift car) $60 - S14 Rear Lower support bar $40 - S14 Blue Subframe Collars $20 - S14 Driveshaft tunnel brace Engine/Drivetrain/Fuel $60 - S14 Fuel Tank Straps $250 - S14 Chasebays Power Steering Reservoir/Lines Set $60 - S14 Cruise Control assembly $50 - S14 Fuel Filler Neck $10 - S14 Fuel Filler Neck Hose $30 - S14 Power Steering Cooling Hard lines $40 - S14 ABS Pump Assembly (95 Zenki) $30 - S14 Rear Exhaust Heat Shield (bolts on above muffler) $25 - S14 Center Exhaust Heat Shield (bolts on above catalytic converter) Exterior $15 - S14 Zenki/Kouki Turn Signal Housing (lens damaged, LH and RH available) $30 - S14 Zenki/Kouki RH Turn Signal $40 - S14 License Plate Light $75 - S14 Windshield Wiper Cowl Cover $250 - S14 Wingless Trunk $200 - S14 Zenki LH Fender (Mint) $50 - S14 Zenki RH Fender (Dented, but easy repair) $150 - S14 LH Rocker Panel (cut where it meets the quarter panel) $250 - S14 Subframe Mounting Studs $25 - S14 Zenki OEM Bumper (trimmed for large FMIC) $200 - S14 Zenki OEM Bumper Support with retainer $50 - S14 Rear Bumper Support (three available) $15 - S14 Rear Bumper Brackets $25 - S14 Rear Factory Tow Hook $75 - S14 RH A-Pillar Exterior Trim $50 - S14 RH Quarter Glass (no trim) $10 - S14 LH or RH Weatherstripping Retainer $75 - S14 LH Door Window $75 - S14 RH Door Window $40 - S14 Rear Glass Lower Finisher Trim $25 - S14 Kouki RH Door Handle $25 - S14 Zenki Hood Prop $50 - S14 Wiper Linkage Arm Set $20 - S14 Windshield Wiper Cowl Metal Cover $30 - S14 Fuel lid door (two available) $50 - S14 SE Trunk Support Bars Interior $20 - S14 Dome Light $15 - S14 Antenna wiring harness $100 - S14 Fuel lid release cable with brackets (fuel lid only, no trunk release on this model) $15 - S14 LH or RH Door Handle Bezel |
09-04-2022, 01:04 PM | #2 |
The Architect.
$50 - S14 Cluster Bezel $15 - S14 Throttle Pedal Stopper $25 - S14 Turn Signal/Wiper Stalk Holder / Bracket $20 - S14 Lower Dash / Steering Column bracket (three available) $40 - S14 Wiper Stalk $35 - S14 RH Kick Panel $100 - S14 Heater Core Box (removed from a '95 Zenki) $30 - S14 Speaker Door Bracket Set $15 - S14 RH Door Speaker Bracket $15 - S14 RH Triangle mirror cover $30 - S14 LH/RH Triangle mirror cover set $15 - Steering wheel spacer $10 - black spin knob $30 - S14 RH A-Pillar $75 - S14 B/C Pillar Set $15 - S14 Rear Seat Airbag Module Cover (prevents middle section on seat from sagging) $25 - S14 Rear Seat Striker Bracket $30 - S14 Fuel Pump Sender Cover Suspension/Brakes $100 - S14 Rear Knuckles $30 - S14 Rear Subframe Braces $100 - S14 Brake/Fuel Hard lines (NON ABS) $100 - S14 Brake/Fuel Hard lines (ABS) $400 - S14 GP Sports Coilovers (1 Front has a bent shaft. Straighten it out and run it on a cheap drift car) $60 - S14 Rear Lower support bar $50 - S14 Blue Subframe Collars $20 - S14 Driveshaft tunnel brace Engine/Drivetrain/Fuel $60 - S14 Fuel Tank Straps $250 - S14 Chasebays Power Steering Reservoir/Lines Set $60 - S14 Cruise Control assembly |
09-04-2022, 01:04 PM | #3 |
The Architect.
$10 - S14 Fuel Filler Neck Hose $30 - S14 Power Steering Cooling Hard lines $100 - S14 EVAP Box Assembly ('97 Kouki) $40 - S14 ABS Pump Assembly (95 Zenki) $30 - S14 Rear Exhaust Heat Shield (bolts on above muffler) $25 - S14 Center Exhaust Heat Shield (bolts on above catalytic converter) |
09-26-2022, 01:48 PM | #4 |
The Architect.
Updated post. Adding significantly more parts this week.
10-08-2022, 02:19 PM | #7 |
The Architect.
Listing updated. Adding significantly more parts over the next few days.
10-20-2022, 11:29 AM | #8 |
i'm down to meetup for the tow hook
11-08-2022, 04:24 PM | #9 |
The Architect.
Updated the main posts.
Adding more parts this week. |
