Old 08-25-2014, 10:26 AM   #1
iBelarryfool
iBelarryfool's Avatar
iBelarryfool is an unknown quantity at this point
My s13 Journey (pic heavy)
I picked up my 1990 240sx hatch in 2013 completely bone stock
Stock SOHC KA24E with 110k
decided to go with the SR20DET with 40k
Then the process started
Moving to my shop
Getting the car ready for paint
Cutting out the one rust spot from the battery
Engine bay Candy blue with gold pearl
Time to work the dash
Time to work the inside...
testing the SR
time to go to through the SR
During the process of going through the SR and replacing bearings, all gaskets, exhaust studs, etc, we pulled the bottom and found that the bearing was spun and destroyed the bottom end....
So instead of building the SR Ive decided to go with the 2jz-ge.
Bought the block off of a friend
ARP!
upgraded Throttle body 80MM
After a few months got it together
Bought a R154!
Got my valvecovers done by a friend
On to the test fit!
I have some clearance issues with the front facing manifold i bought due to size being to big so i may have to go with a brake booster delete and a tubed front end. will keep you guys posted on updates!
thanks for checking it out
iBelarryfool is offline   Reply With Quote
2jz, build thread, drift, s13 240, turbo
