Old 09-21-2015, 02:47 PM   #1
Soilsack
Soilsack's Avatar
Soilsack is an unknown quantity at this point
Nissan Quest Alternator Problems
Hey guys. I am having a problem with the Nissan Quest alternator in my 1998 Nissan 240SX. My problem seems to be slightly different than anything else I searched. I installed the quest alternator, modified it accordingly, and got a slightly longer belt. Install went ok other than the fact that the top mounting hole for the tensioner bracket does not line up to the slot that the bolt goes through. So right now I have no tensioner on the alternator. I wedged a pry bar in the alternator and pulled against it while a friend tightened the bolt for the mounting bracket. It seems to keep tension that way but I don't want to rely only on that. Does anyone know of anything that can be done to make sure that the tensioner will mount up?
Soilsack is offline   Reply With Quote
Old 09-28-2015, 03:43 PM   #2
Soilsack
Soilsack's Avatar
Can anyone help in this? I'm not sure what to do. I was thinking about notching the alternator top mounting point to feed a bolt through and attach a nut on the other side.
Old 09-28-2015, 04:01 PM   #3
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Try sending codyace a pm. He's the one that makes the brackets for them.
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 10-03-2015, 05:20 PM   #4
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Post number 10.
http://zilvia.net/f/showthread.php?t=606447
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 10-03-2015, 08:49 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
You have to loosen the bolts where the tensioner bracket mounts to the timing cover. It will shift around enough for the slot to line up.
