03-19-2015, 12:07 PM | #18001 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
^^^ THIS! alternators are nothing special, take it and have it rebuilt. itll be good as new and you wont need to worry about a used one possibly taking a shit after a few months! |
03-19-2015, 12:58 PM | #18002 |
Yes, Ill be buying a rebuilt g20 alternator. Its just because no local shops have rwd sr parts and i need something that will fit. I need it quick too which is why I opted not to get mine rebuilt now.
03-19-2015, 01:29 PM | #18004 |
I always have rwd sr20 alternators rebuilt at the local alternator and starter rebuild shop. I don't even tell them what car or engine it's for, just drop it off and pick it up later that day with a 1 year warranty for $60 bucks, which you'll never get on a used part. Have never had an issue with them either.
They aren't some crazy unique part, forget about the whole rwd/fwd thing and just drop off the original one for a rebuild. |
03-19-2015, 02:03 PM | #18006 |
What is the size mm and/or inches for the stock water temp gauge?
On a 98 240. Want to know if I can fit a 52mm gauge in there. Thanks
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
03-19-2015, 02:18 PM | #18007 | |
I also just went to the local rebuild shop, the man smoking his cigarette while removing an alternator core told me if the bearings have fully seized he would not want to rebuild it as its probably destroyed. Guess ill have to order one in offline now. Thanks to everyone. |
03-19-2015, 04:38 PM | #18009 | |
1234 |
03-20-2015, 10:09 PM | #18011 |
Trader Rating: (24)
Feedback Score: 24 reviews
I don't think there are any. HPS was it as far as I remember.
I think carbotech or porterfield will make any sort of brake pad you want, but I'd argue that it's easier to just switch to Z brakes, instead. |
03-22-2015, 04:03 PM | #18013 |
if both are RWD, should fit with no mods at all. The only difference between DE, and DET RWD is the head. T head has minor differences
03-22-2015, 07:37 PM | #18015 |
Philosopher King
E brake light stuck on. Dims when on throttle. There is a buzz in the fuse kick panel that coincides with the light as well.
Brake fluid is topped off and there is no apparent damage to any of the calipers. Tried searching here but found little more than hearsay and bickering.
G O L D E N B E A R R E P U B L I C |
03-23-2015, 01:46 AM | #18016 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
my last s13 did this after i swapped over Z32 front calipers for a bit, eventually went away. never could figure out what was causing it. |
03-23-2015, 08:09 AM | #18017 | |
That'll be $65 for the troubleshooting work. Welcome to the 21st century and online work. I'll PM you my PAYPAL and contact information if you prefer to send a USPS money order
03-23-2015, 12:28 PM | #18018 |
Idk if this question should be on this thread but I can't seem to find the answer, so forgive me if I'm not doin it right...please lol
Anyways I have two red top 62 ecu's, one is tuned by mines the other is stock. they both don't seem to be workin and would like to get them checked out/ fixed. Dose anyone kno of a place or how to go about this?? I'm located in SoCal 92236 Also, if anyone has a s13 sr20det red top compatible Ecu im interested... |
03-23-2015, 02:11 PM | #18020 |
So I have a personal steering wheel and circuit sports quick release. Pretty much like the 2.0 version of the NRG qr. the horn button is not fitting into the quick release. I have tried numerous times. Will I have to get a newer version of an NRG quick release for it to fit or what is the issue ?
03-23-2015, 02:35 PM | #18021 |
Anybody here good with bee-r's? I hooked mine up and it works fine on rev 2. When I turn the knob it changes the limit just like it should with the ebrake up. But driving with the ebrake down no matter where rev 1 is set, the car cuts at 3500. It revs perfectly fine with the unit off, gain turned to 0, but as soon as I set it to 1 it cuts at 3500. Idk what the problem could be, any suggestions?
03-23-2015, 03:08 PM | #18022 |
Just a dumb question. I'm modying my car and right now i'm on the suspension setup. I've already bought coilovers and energy suspension bushing kit for all the parts.
A few days ago i've read something about anti-sway bar importance in drift. But my question is: how do japanese do their suspension setup because on every movie i see on youtube, their cars are very precise, good stability, predictable and the most important thing, they can drift and make mass changes at high speeds. Their cars response very good. What is the recipe? I would like to do: coilovers, bushings, upgrade rear sway bar, stock sway bar in front, power by max knucle, tein or pbm tension rod, etc...But i'm still confused how to they do. The drift cars from my country have a lot of power (600 bhp some of them). But they are slowly. They make mass changes very slowly, they aren't fast in drifting...They feel heavy when you are watching them drifting. Every video i see from japan, their cars are fast in drifting, quick mass changes, very good stability, very good suspension setup, even if they have 300 bhp. I'm a little confused. Thanks |
03-23-2015, 04:25 PM | #18023 |
Philosopher King
The switch is working and there is no blown fuse or a fuse for the switch to begin with. Thanks for being a by the numbers Zilvian.
03-23-2015, 05:34 PM | #18024 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
did you upgrade to Z32 brakes upfront? is one of your rear calipers sticking? |
03-24-2015, 05:59 AM | #18025 | |
E-Brake, switch, and a stuck on light in the dash. Guess what, you get to take off your steering wheel if you have a QD set up, pull out the four screws, two side plugs, and the three rear plugs so you can pull the cluster out, all the way out. You have a short in the circuit, and the most likely spot is the cluster itself. Pull the light out, it's a ebrake light that says your e-brake is on. Do you really need it? Unless you want to trace the switch wires to follow them and look for a short(might be one, might not), the easiest thing is to simply delete the light
03-24-2015, 01:53 PM | #18026 |
Philosopher King
That light is also the brake fluid level warning light and I'd rather not suffer a sudden brake failure and crash that could have been avoided had I not done some janky ass bullshit.
I don't know why I expected any other kind of response here. You'd think a known issue would have a known solution to go with it.
03-24-2015, 02:24 PM | #18027 | |
03-24-2015, 09:46 PM | #18028 | |
03-25-2015, 06:43 AM | #18029 | |
Now take your happy ass out to your car and get to troubleshooting, because you ain't gonna find the solution here. You have a new switch, the bulb works, so find the shorted wire and fix it. No one is going to be able to tell you which wire is shorted, and everyone will say that light staying on is a common problem in early model Sentra's, 240's, and Altima's which all share the same basic electrical functions and cluster parts, or steering wheels. So instead of fucking with me, get your ass to your car and troubleshoot that bitch, bitch. Me, I'm going to check FEDEX to see if my valve cover gasket is in, go hit up Advance Auto for some silver paint, and fix my car. You want everyone else to try to diagnose your junk from anywhere but your car, hang out, get nothing done. You know know where teh problem is, so go find it!
03-25-2015, 06:38 PM | #18030 |
Philosopher King
All I'm asking for is basic where to look shit, man. There's no need to rip my fucking car apart looking for god knows what if thousands of other people have already fixed the very same problem on other vehicles. No need for shitty attitude right out the gate, especially when you offer no viable solutions.
The fact that the buzzing intensity and brightness of the light seems tied to the RPM makes me think that something is up with the alternator or a ground associated with the warning light circuit.
