Old 08-08-2019, 09:57 AM   #1
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
SR20det does not rev past 4k
Hey guys,
I have a fully built sr20 tuned with a AEM v2 and map sensor. It starts up and revs fine until it hits 4k and backfires and will not rev past 4k. Zero boost leaks as I tested it. Any ideas would be appreciated or if you are super familiar with AEM and want to read my data log.
Again AEM v2 with a map sensor.
Thanks
JohnnyDrfiter22 is offline   Reply With Quote
Old 08-08-2019, 10:14 AM   #2
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Just curious as to if the 2 step was set up incorrectly?
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 08-09-2019, 04:28 PM   #3
ultimateirving
ultimateirving's Avatar
Have you checked the coil packs ? Boost leak test ? What about your plug gap and heat range ?
Z32 with lq4 swap
Old 08-10-2019, 11:34 AM   #4
JohnnyDrfiter22
Coil packs are good, they have spark. That was my first assumption.
No boost leaks, I bought a tester.
Plugs are BKR7E gapped to .27.
Old 08-11-2019, 08:17 PM   #5
ultimateirving
Spark doesn’t mean they are good. Can you swap with a known good set. Or put yours in a good running car?
Typically failing coils will fire under light load and breakup badly once you start to get under more load
Z32 with lq4 swap
Old 08-13-2019, 02:14 PM   #6
JohnnyDrfiter22
That makes sense. I have a few spares. I'll throw them in and see what happens.
Old 08-16-2019, 05:24 PM   #7
JohnnyDrfiter22
I changed out the coil packs and no changes. I'm stumped!!
Old 08-16-2019, 08:53 PM   #8
Jfornachon
Jfornachon is an unknown quantity at this point
Have you checked your tune? No mention of that reply.
Are you map or mf?
Have a great day,
jared
Jfornachon is offline   Reply With Quote
Old 08-16-2019, 10:18 PM   #9
inopsey
inopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant future
what does your wideband read when this happens??
inopsey is offline   Reply With Quote
Old 08-20-2019, 12:38 PM   #10
ultimateirving
How much boost? I remember with stock coil packs, my engine worked better with the copper plugs. As soon as I switched to the ls style coil packs, I switched to iridium plugs and those worked better.
Z32 with lq4 swap
