Old 07-26-2020, 09:02 PM   #1
Darfin
Darfin is an unknown quantity at this point
Blowing the 75Amp Main Fuse because of Engine Cont fuse?
I've been referring to the FSM so far and nothing has solved my issue. (89 240 with a KA/DE)
Basically, my 75 amp fuse is blown due to a possible grounded power somewhere, and there is continuity between power and ground even when the lower harness (alternator/starter harness) is completely disconnected.
However, when I unplug the 30 amp "Engine Cont" fuse, there is no longer continuity in the 75 amp (and the car won't start due to no spark when the Engine Cont fuse is unplugged).
My issue is I cannot find what all the "Engine Cont" 30 amp (not the 10 amp) fuse is connected to, and possible areas to look for a grounded out power. Any help is appreciated.
I've been told that the "Engine Cont" fuse powers the distributor and the ignition coil, however I can't find any frayed wires leading to either, nor can I find a diagram that tells me exactly what is wired to that fuse anyways.
Darfin is offline   Reply With Quote
Old 07-27-2020, 08:17 AM   #2
jedi03
if you dont see anything external than its possible that something fried internal to those items...you definitely have bad ground somewhere with that popping...
Old 07-27-2020, 08:54 AM   #3
S14rebuild
Start disconnect things, that could be shorted out
Try alternator and starter... they could be the cause of ur short..seen it before
75 amp, engine cont, fuse, grounded out
