04-27-2012, 02:21 AM | #1 |
Manual Hatch 91 240SX 96 KA24DE excellent compression & Parts
Selling a clean manual 1991 240SX with a 1996 DOHC KA24DE with excellent compression PLUS extra value parts.
-150k miles on Chassis and 150k miles on engine (partial rebuild). -The car is a hatchback with a Silvia front end and a body kit (side part of body kit installed, need to update photo). The status of the various parts of the car are found in the list below. -There are no outstanding fees due on this car. -The car has not been SMOG'ed yet. The CAT has been inspected (see comment in list). -The car is currently on PNO because I didn't want to have to pay for insurance while I was working on it in the garage. -TITLE IN HAND. -Dash has minor crack near one of the vents -Glass is tinted and not cracked -Complete interior (nothing missing) EMAIL me with your CONTACT NUMBER if interested. My schedule is a bit busy so I may not respond immediately. Selling for $4000 OBO as-is. Counter offers through email are worth as much as the paper it's printed on. Instead we can meet up and you can make a serious cash-in-hand offer in person. Valid license and insurance is required for a test drive. Cash only (bank transfer okay), no delivery, no trades for services. VALUE ADDED PARTS (all for 240sx): -VLSD with half axels!!! (Drift it!) -Extra bumper with foam (you know you'll need this) -1996 240SX Automatic ECU (no rev limiter) -Extra stock exhaust manifold -Electric seat belts (if you want to reinstall it) -2x Extra engine fans -Electric Radiator fan -Plastic gauge housing -Extra CAT (good condition) -Extra 1991 power steering pump -1 inch wheel spacers (to make the rear wheels extra sweet) -Extra Oil Filter -Distributor cap -Steering ties and one pivot -Brand new frame member ($50) in case you bottom out and want to replace your rail THE CAR: Transmission All gears ok; no metal shavings in oil;current new oil (passed new oil through tranny twice);cleaned Transmission Sensors All new flywheel & push plate (XTM) All new Push bearing & fork inspected ok Drive shaft mount one side larger screw size (double check) Performance Tires 90% tread life (2x Hankook Ventus V4 & 2x Achilles ATR Sport) 96' Engine PSI KA24DE 180-204-175-180;cleaned Spark plugs (NKG) all new distributor inspected ok distributor rotor & cap new Emissions equipment inspected ok Spark plug cable new Valve cover gasket new timing cover gasket new timing chain and sprockets inspected ok for wear and timing valves and levers visually inspected ok oil pan gasket new oil pump original from 96' engine oil filter (purolator) new engine mounts (Nismo) new racing steering wheel (Grant) inspected ok shifter boot new rubber hose in engine bay ~95% new engine filter (K&N) inspected ok ignition coil inspected ok battery duralast inspected ok;kept on tender power steering rack new radiator (Griffin) performance water pump new accessory belt new Air conditioning Deleted;inlet and outlet to cabin sealed silvia front end JDM coolent new starter motor New alternator inspected ok power steering pump inspected ok coilovers are tein super sport shock tower bar CAT inspected ok (was cut out, inspected by a CAT business, then reinstalled) front crank shaft ring new carbon fiber hood windows inspected ok general body panels no dents general frame inspected ok radio Deleted rear speakers uninstalled fuel injectors inspected ok clutch master cylinder new clutch slave cylinder new fuel filter new freeze plugs new electric shoulder seatbelts uninstalled;have parts Chassis 148k previous gauge cluster;178k current gauge cluster;unpainted but primered;body kit exhaust manifold gasket new intake gasket new collector gasket new IAA gasket new throttle body gasket new oil filter base gasket new EGR valve gaskets all new head gasket inspected ok piston assembly inspected ok transmission mount (Nismo) new flywheel bolts some new Thermostat new Body Kit inspected ok |
5speed, ka24de, manual |
