05-16-2011, 08:07 PM | #1 |
Trader Rating: (163)
Feedback Score: 163 reviews
S15 SR, Fully Built Parts, S13 Shell, 6-Speed SR Trans Etc.
I bought the following from a good friend of mine to help him out of a jam. I got a good deal, so I simply want to resell it for a little profit. And actually, this was originally the built setup I was going to buy before I decided to go the LS3 route.
NOTE: Since I am out of space at my house and shop, I am storing all of it at a friends shop out of town. So please allow up to a week, after purchase, in order for me to go get the purchased item and get it boxed up and shipped. Feel free to contact me to try and make special arrangements for faster shipping. My friend makes the trip in town quite often, so he may be able to bring the purchased item to me quickly. Please contact me for shipping quotes. All of the motor items; block, head, internals have been stored in a humidity controlled room. Freshly Prepped S15 SR short block decked, cleaned and bored for CP Pistons listed below. Includes Crank $399 SOLD!!!
Freshly Prepped S15 SR head: Decked, cleaned and 3-angle valve job: $399 SOLD!!! Includes the following new items installed
BNIB CP Forged Pistons SC7325 86.5mm 9:1: $449 BNIB Eagle CRS5365N3D SR20 Chromoly Forged Connecting Rods: $269 SOLD!!!! BNIB Mazworx MAZ 11002 Main Stud Kit: $157 SOLD!!!! BNIB Brian Crower BC0202 Stage 2 S13 Camshafts: $259 SOLD!!! BNIB Tomei 13024R310 Adjustable Camshaft Gear: $135 BNIB OEM Nissan Water Pump Assembly: $45 SOLD!!!! BNIB Nismo 21200-RS520 Colder Thermostat: $55 SOLD!!!! BNIB Full Timing Chain Kit: $119 SOLD!!! BNIB 8 OEM Nissan 13234-53J01 Lifters/Pivot Rockers: $199 BNIB OEM NIssan 13257-53J03 Rocker Arms: $189 BNIB RP Sports SR20 Digital Valve Shim Tool: $145 BNIB ARP 102-4701 Head Stud Kit: $109 SOLD!!!! BNIB Circuit Sports RAS-SR1345-PH: $39 SOLD!!!! BNIB Cosworth 20000924 Head Gasket 87mm ^ 1.1mm: $119 SOLD!!!! BNIB OEM Nissan Full Gasket Kit: $129 BNIB Clevite TW-590S Thrust Washer Set: $44 BNIB Clevite CB-1629 P-.25mm Rod Bearing Set: $44 BNIB Clevite MS-2015P-.25mm Main Bearing Set: $50 BNIB Wiring Specialties S15 SR - S13 Chassis upper and lower harness: $255 Stock S15 SR20DET Parts: Make offer unless noted
Greddy V-Spec Core Only: $400 LHD Nissan Nabco BM50 1" Brake Master Cylinder Non-ABS: $115 SOLD!!!! (Mint condition. Note: this is for non-ABS cars. Already has 3rd fitting pressed in... it's ready to go.) Polished Golden Eagle Vacuum Box: $29 (Earls fittings and/or lines are extra. Contact me if you want to discuss it) Unknown Downpipe: $80 Apexi GT-Spec Exhaust: $250 Unknown Steel Driveshaft for 6-speed into S13 chassis: $100 Koyo Radiator: $150 Apexi Filter kit w/S15 MAF and elbow: $50 SOLD!!! S13 1989 Hatch Roller: Make offer! I will not part out... I don't even want to mess with it nor do I have the time.
05-16-2011, 09:48 PM | #4 |
Trader Rating: (60)
Feedback Score: 60 reviews
Mannnn you got some sexy parts for sale! I probably don't have enough money to ship the exhaust but how much to ship 90280
Want to roll fenders, custom gauge pod pm me |
05-20-2011, 11:50 AM | #10 |
Toby, do you know the condition of the PS Pump? My car squeals pretty loud at start up. I'm suspecting the pump is starting to go. And i'm guessing it would be a direct bolt on to an s13 sr.
05-20-2011, 05:51 PM | #12 | ||
It would be $70 to ship it. Quote:
I won't be shipping fenders.... which is the reason I do not want to part it. I shipped my Silvia fenders and it was a total pain in the ass. Expensive and difficult to pack up properly. I'd sell the whole damn car for several hundred dollars..... the rear-end alone is almost worth that. Someone just needs to come pick it up. I simply do not have the time to mess with it.... Sorry! |
05-21-2011, 08:56 AM | #14 |
If the gasket it Is for an s13 sr n includes the following I'll take it,
Brand new OEM SR20DET Engine Gasket Kit. Comes with everything you need for a complete engine rebuild.* See list below to find out what is in this kit.* Please specify your motor when ordering. Gasket – F.I.P. (150g) Gasket – Cylinder Head Gasket – A.A.C. Valve Gasket – Collector Intake Gasket – Intake Manifold Gasket – Exhaust Manifold Gasket – Turbo Charger Inlet Gasket – Turbo Charger Outlet Gasket – Inlet Tube Air Gasket – Inlet Tube Gasket – Oil Tube Inlet Gasket – Connector Water Gasket – Oil Tube Outlet Gasket – Oil Filler Cap Gasket – Chain Tensioner Gasket – Rocker Cover Gasket – Throttle Chamber Oil Seal – Crankshaft Rear Oil Seal – Valve Exhaust Oil Seal – Valve Intake Oil Seal – Crankshaft Front O-Ring – Oil Strainer O-Ring – Sear O-Ring – Injector Upper O-Ring – Seal O-Ring – Injector Lower O-Ring – Support Distributor Washer – Drain Plug |
05-21-2011, 10:41 PM | #17 |
Hatch
You're just full of surprises, aren't you? Where did this hatch come from?GLWS. Thanks for the oil catch can. I really love it.
DAOUD AKA KONGO DAVE |
05-22-2011, 01:58 PM | #19 |
As far as I could tell, only in the area where it is shown in this pic. They are not horrible, but probably a little worse than just surface rust. If you are serious I can always try to get some better pics of the specific areas. Or if you are close you can just come look and make your own conclusion. Because my definition of shitty may be different than yours. I would take $500.... which the rear-end alone is worth that much.
Let me know if you want to come take a look. Toby |
06-01-2011, 08:26 PM | #27 |
I can do that.
Yes, all SR blocks are the same.... it's the head that's different from the S13 to the S14/15's. For the shipping, is it going to a business or residential? Do you need lift gate service? As long as you have a friend you should be able to lift it off the trailer. Just so you know it's a little cheaper to ship to a business. |
07-19-2011, 01:57 PM | #29 |
interested in the s15 ecu. still have it.
well im writing this for a buddy of mine, he need one how much shipped to 60638 and are the both know to work properly? |
brian crower, built sr, cp pistons, eagle, s15 sr |
