Old 09-01-2016, 07:31 AM   #1
jisatsu
jisatsu is an unknown quantity at this point
Rb25det S2 starting problems
So I have an s13 with rb25det s2
All stock except t3 rep turbo and LS2 truck coil packs and j30 maf
Ran fine for months....
One day, while I was driving, it felt like it loss fuel and cut off, but when I gave it gas, rpms still moved up and down. Of course, car is dead and just rolling in neutral. Let it sit for 30 minutes and started working again...
Next day, I drove normally to work fine... on the way home, I decided to push it a little, and it did tthe same thing... can feel motor cut off as If no fuel... but rpms still go up if give gas but doesn't move other than rolling in neutral.... til motor is to a complete stop.... 30 min later, starts up fine
Next day drove normally all day with no problem....
Day after, changed out fuel filter thinking I fixed it.... so to took it for a drive... dies again when I give it extra gas... now it won't start... motor turns over fine, but it won't start....
Bad relay.... that finally gave up???
Please help.
jisatsu is offline   Reply With Quote
Old 09-02-2016, 11:46 AM   #2
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
Have you checked your gas tank filter? And pump? Maybe its old and worn?
Also if it was getting fuel cut I dont see how the RPMs will keep rising and car not moving, that sounds more like clutch slip.
Check your fuel lines, pump, pump filter sock, FPR.
Nissan2nr22 is offline   Reply With Quote
Old 09-02-2016, 01:14 PM   #3
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
You listed every symptom of a dying CAS. Test it and replace if necessary.
dbeiler is offline   Reply With Quote
