Old 03-14-2011, 04:41 PM   #1
1997silvia
1997silvia is on the path to ruin1997silvia is on the path to ruin
pfc sr20 cold idle problems????
i have a power fc on my s13 with a steve shadows tune in it, its good at wot but cold starts are terrible, it will stall out 5 or 6 times after 7 or 8 seconds until the water temp starts to warm up, i believe my problem lies with the water temp correction tables, i have played with it and no luck, i have noticed that my wideband goes lean right before it stalls out, so does anyone have cold water temp correction values that work?
thanks in advance
1997silvia is offline   Reply With Quote
Old 03-14-2011, 09:57 PM   #2
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
best thing we can recommend is to obviously talk to your tuner first.
did you use his online service or did you get it physically tuned by him?
which power fc do you have d-jetro/l-jetro?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 03-15-2011, 09:35 PM   #3
inopsey
the problem is the fuel map. add fuel to the area of the map where the cursor is on the map trace during idle. add fuel to adjacent cells also
Old 03-16-2011, 03:48 PM   #4
1997silvia
i have the map based version, also i tried to mess with the water correction values and it definetly helped a lot!! i know i need to get it on a dyno and get a better tune but this is working until i find a excel pfc tuner around pa, i dont have datalogit software i to have the commander though, but if you can be a little more clear about what columns to change i can do it through the commander thanks in advance
Old 03-16-2011, 03:51 PM   #5
statickx991
statickx991 is an unknown quantity at this point
go to matt at importintelligence.com down in west chester, or jeff evens or r/t tuning
matt tuned my d jetro on my built sr and runs like a champ
im a f18 bro
statickx991 is offline   Reply With Quote
Old 03-16-2011, 05:22 PM   #6
1997silvia
ill check out matt , and i have heard about jeff evans, but what is r/t tuning? thank you so much for the information
Old 03-16-2011, 07:40 PM   #7
inopsey
on the commander screen there is monitor settings and etc. choose monitor. on the next screen it will ask you to choose 1-8 channels to monitor(boost, water temp etc) or map watch choose map watch. the dark cursor is the cells being currently used by the engine
Old 03-16-2011, 10:18 PM   #8
statickx991
rt tuning is in landsdale. but matt deff hooks it up with tuning. good people there and you prolly seen him drifting. he holds those "drift camp"s with like elite jdm and whatnot. and no problem. where in pa are you?
im a f18 bro
Old 03-19-2011, 11:30 AM   #9
1997silvia
i am in mercer pa, about an hour north of pittsburgh, how about you?
