Old 09-19-2019, 02:46 PM   #1
jroll
jroll is an unknown quantity at this point
No O2 sensor voltage B1-S1 at ecu
I have having trouble running rich out of the exhaust, when I plug the OBDII scanner into the port it reads that its not getting no voltage at the O2 sensor (lean bias) so now my fuel trim is super high and its running rich out of the exhaust. I checked the voltage from the 02 all the way to the ecu pinout and it was good. I have no codes and the car runs great, it wont pass smog though.
jroll is offline   Reply With Quote
Old 09-19-2019, 07:08 PM   #2
jroll
Any thoughts anyone? I get .780-.820 MV from my O2 but my ECU/ECM reads 0.000
Old 09-19-2019, 07:41 PM   #3
S14rebuild
Well that means u have an open wire somewhere...start checking the harness
Old 09-20-2019, 06:52 AM   #4
jroll
My harness checked out, I was thinking ECU? But I don’t wanna shotgun it and waste $150
Old 09-20-2019, 07:39 AM   #5
S14rebuild
Well if ur pin testing at the harness ecu connector n ur reading voltage, but ecu says its reading nothing, then that would confirm a bad ecu
Old 09-25-2019, 03:26 PM   #6
jroll
I ended up buying a new (used) ecu and it worked out. Thanks
Old 09-25-2019, 05:22 PM   #7
S14rebuild
Glad worked out good for u
