Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
01-02-2012, 10:53 PM | #1 |
240z Distributor help
I need help figuring out the distributor. I have a 1972 240z stock motor (head and block). This is the first time ive owned a car with a distributor so im not too familiar with them.
Is this the right numbering for the wires? I numbered it this way based on the firing order givin in the manual. I did not change any of the wires, so this is how the previous owner left it. Also to confirm, this is the right firing sequence? Is this the adjustment i use when timing with the light? Or is this the adjustment and if not what is this used for? |
01-02-2012, 11:05 PM | #2 |
Firing order/ at head... did search....
The first bolt is used to adjust timing. The other one im unsure i switched over to the e12-80 electric dizzy. http://datsunzgarage.com/ |
01-03-2012, 01:38 AM | #4 |
Lol you guys are awesome. So my plug wires in the right positions, just that i have my numbering wrong. The numbering i have for the cylinder head is actually for the distributor cap counter clock wise and the numbering from that is for the head.
Got it, Thanks for the help fellow z owners Edit: Found out that the adjustment closer to the front of the motor is for a coarse adjustment, only use it if the other one runs of out adjustment range. |
01-03-2012, 05:38 PM | #5 | |
Cylinders #'s are 1,2,3,4,5,6 From front to back. Firing order is: 15 is too young. 36 is too old, 24 is just right. Counter clockwise hence, 153624. #1 is cylinder is usually closest to radiator and you seem to have it right. Best thing to do is redo the timing. You'd have to remove the plugs, hand turn the crank clockwise to Top dead center. Remove the oil pump insert it back, and make the dizzy rotor line up to #1 of the cap. Sometimes a timing could be 180* off 90* off, which will sometimes still work, but may run like crap. |
01-08-2012, 09:34 PM | #6 |
Well i have bad news, I got the motor in the car and running today but i cant seem to bring the timing to the 5 degree mark. with both of the adjustments on the distributor turned all the way i can only get to the 20 or 25 degree timing mark, the one furthest from 0 mark. Whats my problem? Before i pulled the motor to work on it, i checked the timing and it was at the 5 degree mark, so it was working before. My mechanical timing is right.
Some pics showing my timing. Just took these. I have the light hooked up to number one cylinder. The previous owners put this ignition box thing in. I made sure i have it wired in right, i took pics before i removed it so i could see how it looks when to install. could it be that my distributor drive spindle is off a tooth? so i have to take the oil pump off and reposition the spindle? |
