Old 07-09-2019, 09:29 PM   #1
Nate.Srzenki
Nate.Srzenki is an unknown quantity at this point
Throwing codes and need to pass inspection
I'm getting codes P0335, P0130, P1605, P0141
97 5spd swap...auto ecu I believe is the main issue.
I plan on SR swapping within a year. I just need to pass inspections so I can register, title transfer and cruise it on the weekends.
Any suggestions??
Nate.Srzenki is offline   Reply With Quote
Old 07-10-2019, 09:27 AM   #2
jedi03
they will be only doing visual/tailpipe inspection if that helps point you in the right direction...if the check engine light isn't on then you should be ok
Old 07-10-2019, 11:18 AM   #3
spitefulcheerio
spitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura about
Remove the CEL bulb and call it a day
spitefulcheerio is offline   Reply With Quote
Old 07-10-2019, 12:42 PM   #4
Nate.Srzenki
From what I've been told I still wouldn't pass emissions.
Old 07-10-2019, 10:47 PM   #5
Jfornachon
Jfornachon is an unknown quantity at this point
Most of the time they will still pull codes on an obdII car. What are the definitions for the codes.Pick one and fix it. Help us help you. People here are not going to spoon feed you information. You need to do some of the work and present information.
Have great day,
jared
Jfornachon is offline   Reply With Quote
Old 07-12-2019, 04:19 PM   #6
Nate.Srzenki
Have great day,
jared
All good on my end. I have figured it all out.
Old 07-13-2019, 10:59 PM   #7
Jfornachon
So what was it? Other people can use the information. I can't but someone else may.
Have a great day,
jared
