05-06-2005, 02:57 PM | #1 |
boost controller ?
hey fellas got a little question, i just bought a manual boost controller, like 8 bucks on ebay, and shneider is the brand i believe, and i ran the hose from the wastegate to it and then a hose to the intake manifold, is this correct, it says run it to wastegate and to a boost source, im guessing its a vacuum source, so i did that and then it says turn 1/4 turns to increase boost so i did that like 2 or 3 times and boost didnt increase still at stock boost... can some1 pick me up here. thanks
chris
chris's sr |
05-06-2005, 04:20 PM | #2 |
Do you remember where the wastegate was connected to before? Thats where the other end goes. Its a nipple on the stock side mount (if you still have one) intercooler cold pipe.
05-06-2005, 04:24 PM | #3 |
well i removed the stock bov, and that nipple was part of the hole little unit there and welded up the hole, and i have and hks aftermarket bov, and the wastegate was ran to the intake manifold nipple underneath the throttle body, so i duno should i runt he other hose to the bov?
chris
chris's sr |
05-06-2005, 04:42 PM | #5 |
refer to pg 44 of 61. The picture diagram will help you out. Also, no don't hook up the other hose to the bov...
Boost Controller
I'm driving fast -drew |
