Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA
USA Talk to others in your region.
Old 01-21-2017, 07:28 AM   #1
RyanG012
RyanG012 is an unknown quantity at this point
S14 Silvia brakes.
Can I use 240sx rotors?
RyanG012 is offline   Reply With Quote
Old 01-21-2017, 12:14 PM   #2
RyanG012
Also what pads fit? If any in USDM
Old 01-21-2017, 01:54 PM   #3
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
What are you even asking? Can 240 brakes fit a 240?
lunchmeat is offline   Reply With Quote
Old 01-21-2017, 01:59 PM   #4
RyanG012
No km asking if I need rotors and pads for my JDM s14 SILVIA. but I am in the states can I order standard usdm s14 240sx pads and rotors.
I have tried searching with no luck.
Old 01-21-2017, 02:12 PM   #5
lunchmeat
lunchmeat's Avatar
I think the jdm fronts are 300zx brakes and rotors, and the rears are the same.
But I'm no brakeologists.
Old 01-21-2017, 02:23 PM   #6
RyanG012
Pads may be. The rotors look thinner in the Silvia or i may be crazy who knows
Old 01-21-2017, 02:29 PM   #7
lunchmeat
lunchmeat's Avatar
Any part numbers on the calipers? It's been years since I've messed with s14 brakes.
Old 01-21-2017, 02:30 PM   #8
RyanG012
I'll look here shortly. Thanks for the help🤜🏼
Old 01-02-2018, 04:33 PM   #9
FRpilot
FRpilot's Avatar
S14 JDM Silvia front brake calipers should be the same as z32 4 pot iron calipers (30mm). You need to use z32 30mm pads to fit.
S14 USDM 240sx front brakes are not the same as S14 JDM front brakes. They are a floating (sliding) caliper.
s14 JDM & USDM rear brakes are the same.
All S14 brakes are interchangeable with all S14 chasis. (JDM, USDM, EDM, etc.)
FRpilot is online now   Reply With Quote
