Old 10-30-2012, 12:23 PM   #1
Shawn661
Shawn661 is an unknown quantity at this point
Noob Question
I have my car set at 22lbs of boost but i want to take it down a notch i have a blitz boost controller but i want to know how to pull the boost down do i need a new waste gate or what i know this is a dumb question but i just need a quick and simple answer thanks to anyone that decides to help its very appreciated
1990 Nissan 240sx*sold*
VIP 97 LS400
Shawn661 is offline   Reply With Quote
Old 10-30-2012, 12:55 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Look up the manual for it and it should tell how you to adjust it and lower the boost via the controller.
CLICK HERE!!!
Old 10-30-2012, 01:32 PM   #3
Shawn661
Okay thank you!!!
VIP 97 LS400
Old 11-01-2012, 09:36 PM   #4
hooknbook240sx
hooknbook240sx is an unknown quantity at this point
you can do this by turning down the gain on the boost controller assuming its electronic. however, depending on what your wastegate spring is set at you may not be able to achieve a lower psi without changing out the spring. ex. if the spring is 15psi you cant set the boost to 12, without changing the spring. hope it works out for you
hooknbook
hooknbook240sx is offline   Reply With Quote
