Old 04-18-2018, 03:49 PM   #1
kuipertrooper
kuipertrooper is an unknown quantity at this point
S14 rhd neo
Just posting my build up here mostly just to keep track of my progression with it just gonna add to it whenever I have free time.
Feel free to comment/talk s**t/ask questions whatever idc
I’ve owned it for about 10 months now, my 3rd 240, second s14, when I bought it there was no drive train no brakes / lines / wheels (and steelies don’t count) none of the wiring or interior was put together
I guess team one way out of Indiana did a RHD swap on it and the guy never paid his bill so they possessed it and sold it to someone who let it sit outside for 2 years then I bought it.
It wasn’t half this bad when I first got it either lol
So the first thing I decided to do since I had no motor was to build my own tubs
I actually just went out and bought some trailer fenders that worked pretty well but was kind of a pain with a cut off wheel
After that had to primer and figure out the paint code not gonna lie.. it’s spray paint but I’m super hyped how they turned out
Don’t mind the rb lurking in the background
Which went in shortly after, picked it up off a guy that had it in an s13 that we bought and put an sr in it
Also splatter paint valve covers are so corny I still have yet to paint it
My wheels are exactly what I never knew I wanted: Work ESE - Fs I know they look like vskfs but I’ve never seen them before I bought them off croooober if anyone has pm me I’m curious
Currently running voodoo 13 tension rods, bc coilovers, 50mm extended LCAs and tie rods and 300zx front brakes
Next up was getting my cage put in (I really didn’t want to build it myself because I wanted it to actually be professional/safe
The guy who built it is Travis Griffith, he works at a performance shop building cages and other things. He’s hands down the best welder I’ve ever met, huge shout out to him, he’s built a ton of the cages around here in the Midwest and you can see them as far as Florida.
By the way... painting the inside of a car is probably one of the worst things I’ve ever had to do
Also all spray painted [emoji23] but drift car not sowo build
And then chassis wiring which is the second worst thing I’ve ever had to (still doing) do
And here we have a temporary bs intercooler mock up, a bunch of Ebay piping/intercooler also had most of my wiring specialties harness put in as well also shout out to those guys and yury he’s still answering way too many of my questions
Got the brake lines all flared up bumper to bumper it feels nice knowing they’re all new, despite this is a rust free chassis
Went with the VILLAINS hydro kit could’ve made my own but the simplicity/convenience of their setup is worth the price they’re asking sadly you can’t run 300zx rears tho
Then I got my interior semi finished up, I do now and really couldn’t ask for more except a different steering wheel
Sorry I know I’m a dick but the mint door cards had to be cut :/
Now I have the motor ready to start up, well, waiting on a boost controller running into some wiring issues with it, I have power at my ignition relay but my fuel pump doesn’t prime and no crank. I’m sure it’s something simple I’m missing, but not against running everything on an individual switch.
kuipertrooper is offline   Reply With Quote
Old 04-25-2018, 06:11 AM   #2
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Sick build man! That grey s14 tho
S14Serge is offline   Reply With Quote
Old 04-25-2018, 09:43 AM   #3
dalecl9
dalecl9's Avatar
dalecl9 is an unknown quantity at this point
Thoroughly enjoyed scrolling through this, Im getting ready to start on my tubs, did you use 10 inch trailer fenders?
dalecl9 is offline   Reply With Quote
Old 04-25-2018, 08:44 PM   #4
kuipertrooper
I loved that car it was my first one bought it bone stock
Old 04-25-2018, 08:46 PM   #5
kuipertrooper
Thanks man, I’m pretty sure they were 10”, could’ve been 8 honestly I just remember them not being quite wide enough
Old 04-26-2018, 05:12 PM   #6
garrettlee1911
garrettlee1911 is an unknown quantity at this point
im diggin the paint on the cage, clean work
garrettlee1911 is offline   Reply With Quote
Old 04-26-2018, 07:30 PM   #7
kuipertrooper
Thanks man I made sure I never had to do it again www
Old 04-26-2018, 09:10 PM   #8
kuipertrooper
Finally got this mf running had to do some work with the interface harness but now I realized the maf was toast, tested mine and the coil lights up but the voltage doesn’t stay at .8 or rise to 2.0 when air flow Is current but luckily I have a brand new spare laying around just series 1 vs series two so I need to wire it up
Old 05-01-2018, 10:23 PM   #9
kuipertrooper
I could really use some ideas here I’ve read and read and read on so many different things, I just want to get this thing running,
I Replaced the maf, fixed all vacuum leaks/kinks in some hoses, fuel pressure is good 52psi, I’m really not sure on what else to look for here when I get it running (usually without the maf plugged in and several attempts of trying to start it up) it idles perfectly besides running really rich and at 1500-2000RPM so I don’t think my CAS wheel is off/not working because I don’t believe it would idle without any misfires? Unless it’s intermittent? Tried unplugging the TPS got it to start and idle at a really normal RPM (800-900) just can’t get it to do it again, there’s gotta be something stupid I’m missing here everything should be working correctly
Old 05-02-2018, 09:06 PM   #10
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
+1 for Travis, the work he does is fucking unreal.
Cool build man! Hope to see this thing at ODC
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 05-03-2018, 01:10 AM   #11
kuipertrooper
I couldn’t ask for anyone better to put my cage in, seriously, and I hope so too, as long as I can get my issue figured out within the next couple weeks I should be there
Old 05-03-2018, 04:58 PM   #12
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
You haven't really noted what exactly your engine performance issue is. The high idle? The high fuel pressure?
A high idle is an air leak somewhere in or after the throttle body. Plain and simple. Fuel ratio will have zero effect on the engine rpm until the ratio gets far out of stoich.
Disconnect the piping from the throttle body. Verify the throttle is actually closing completely; no bent throttle cable bracket holding it open.
The PCV hose running from the intake manifold to the valve covers must be air tight. The PCV hoses and fittings on the valve covers must be air tight and routed correctly. Oil fill cap must be on tight.
Temporarily block off the air hose to the IAC. Engine should stall out.
dbeiler is offline   Reply With Quote
Old 05-04-2018, 12:30 AM   #13
kuipertrooper
My biggest issue is it just won’t stay on with the maf plugged in and really doesn’t want to start regardless unless it’s pretty warm if anything I think my throttle plate is too closed all the time because if I hold it open just a hair it wants to start a little better
Old 06-08-2018, 07:24 AM   #14
kuipertrooper
So it’s been a while since I’ve posted anything on it, here in the last few weeks I think I have everything running perfect, afr read 14.7, no more dying at stop signs, no more tps issues
Aaaannnd the first ever shake down in the thing
If ya wanna see that vid it’s on our Instagram account bakabeatdown btw
Old 05-16-2020, 06:20 PM   #15
kuipertrooper
Been awhile but I?m alive and the car runs good figured I?d post some pics up how she?s looking rn
Old 05-16-2020, 06:21 PM   #16
kuipertrooper
