10-30-2012, 03:50 PM | #1 |
ca18det swap, no spark just cranks
hey guys, just got done swapping a ca18det into my 89 hatch did all the wiring my self. soldered it and shrink wrapped everything.replaced the waterpump and timing belt. but i did mark my cas before removal,and made sure all my timing marks lined up properly, im running my ka-e maf. went to start it the other day and it just cranked and never fired, i know im getting fuel cause my fuel pump is kicking on and i pulled a fuel line off, so im getting fuel. pulled the number 1 spark plug and no spark. i checked my coil pack ground and my ignitor ground. i also turned my cas and can hear the injectors clicking. i also check the codes on the ecu and it was throwing code 34 which is knock sensor. would my knock sensor not being wired in cause it not to crank? im kinda stumped. help would as to where i should go from here would be much appreciated. cheers
93' sr sil-40 |
10-30-2012, 03:57 PM | #2 | |
Like Me on FaceBook ! |
12-12-2012, 03:30 PM | #3 |
I checked to see if my coils where getting power and they are, I check all my grounds and the resistance of the coil packs it's was .9-1.0. Not really sure where to go from here. Maybe signal wires to my coilpacks?
93' sr sil-40 |
12-12-2012, 04:08 PM | #4 |
just because you have power at each coil does not mean ignitor is working.The coils are ignited by ignitor grounds . If ignitor is bad , no spark at all even if you have power at each coil. I would double check and make sure CAS is installed correctly.
12-29-2012, 02:46 PM | #12 |
Okay I checked the plugs and the only plug I found similar to the one u have plugged in is close to the maf plug, and the pins didn't look to be the same as it do I think I have the right plug plugged in
93' sr sil-40 |
01-09-2013, 06:25 PM | #18 |
Yeah that's what I was thinkin. I'm thinkin it's my ignitor tho. Also I was lookin for the resistor mentioned earlier and I can't seem to find any little metal box anywhere on my harness ? Maybe missing
93' sr sil-40 |
01-09-2013, 06:45 PM | #21 |
I have that metal box thing and engine harness sold recently had it too. That might be your problem. I have no fuel. Fuel pump is dead. But soon ill get my ca running.
I will give you my pistol ammo at the speed of light towards your doom |
01-15-2013, 04:36 PM | #26 |
can you post pictures of the engine harness plugged in to compare with mine. i believe i messed up some where cuz my car wont start either. we in the same boat.
ca18det, ka24de, ka24e, rb25det, sr20det |
