12-26-2011, 11:40 AM | #1 |
Sr wont go over 65 when trans harness is plugged in
Sr in s14
Wiring specialties upper and lower harness Car drove fine when i had the ka harness plugged in w/o speedo. But now that i have everything hooked up the car wont go above 65 & the speedometer reads 115-120mph. Can the speedometer be acting like a fuel cut to the ecu? And why would the speedometer be that far off? |
12-28-2011, 11:36 PM | #4 |
also, you might have a built in speed limiter on the ecu. some older jdm ecu`s have that. i remember back in the day when jdm honda b16a`s were popular. they had a 112 mph speed limiter. we used to use Fields SAFC to defeat it. check on that.
12-29-2011, 09:10 AM | #5 | |
SR's have a speed cut at 120 so if ur gauge is messed up and sending the 120 signal to the ECU then it will cut out
12-29-2011, 09:26 AM | #6 | |
12-29-2011, 09:42 AM | #7 | |
12-29-2011, 10:10 AM | #8 |
I'm assuming you have a s13 SR correct? You need the s14 speed sensor. Quick fix is to cut the yellow/green wire going into the ecu. This is your VSS signal to ecu
www.anarchyperformance.com - Your source for 240sx Performance! https://www.facebook.com/anarchyperformance - Like us on facebook Email: [email protected] |
12-30-2011, 08:42 PM | #9 |
Thanks guys...Wiring specialties makes the harness to work with the SR speed sensor so im pretty sure its not the speed sensor. But it does make sense that id need the s14 speed sensor instead of s13 for it to work with the cluster
Anarchyperf- yes its a s13 SR in a s14 |
12-30-2011, 08:56 PM | #10 |
Missed that part, that's ur issue
12-31-2011, 07:02 PM | #11 |
So get a s14 SR speed sensor and i should be good to go? Guessing both ka and sr s14 speed sensor will work, id just need to rewire the speed sensor plug if i chose to use the ka speed sensor....Correct? Just making sure
12-31-2011, 11:47 PM | #12 |
you gotta match the VSS with the cluster.
S13 Speedo= S13 VSS S14 Speedo= S14 VSS KA and SR are exactly the Same.
s14, speedometer, sr20det, wont start |
