Old 07-05-2020, 01:22 PM   #1
tuzzio
tuzzio's Avatar
S13 / S14 Parts, 5 speed swap, Coilovers, Suspension
**LOCAL PICK UP ONLY CURRENTLY**
Text 413 313 3694
I was told all of these parts were removed from an S14, but seeing the whole 5 speed swap is S13, I?m unsure. I?ll gladly measure anything you want.
S13 5 speed swap: $SOLDSOLDSOLD
First and foremost. I have never used any of these items, and there is a chunk missing out of the bottom of the bell housing as pictured.
-Short Shifter
-cross member with poly mount
-XTD clutch housing
-Competition housing with sprung pressure plate
-unknown flywheel, likely competition
-S13 brake & clutch pedal
-S14 rear knuckles $50
-Blue RUCA: $50
-SPC Traction rods $75
-ISIS CRUSTY EDITION Tension rods: $SOLDSOLDSOLD
S13 FLCA: $45 with ball joints
S13 FLCA $40 without ball joints
Stock RLCA: $SOLDSOLD
Tension rod brackets: $SOLDSOLD
Stock traction rods: 4 pack of red bull
Stock toe rods: 4 pack of red bull
UNKNOWN CONDITION COILOVERS: $SOLDSOLDSOLD
JIC magic front coilovers with fortune auto camber plates, Rear Fortune auto coilovers
I believe the rears are S14, as they seem longer and I cannot get the body to spin in the lower mount.
Aside from that, all collars have been broken free front and rear.
Old 07-09-2020, 10:23 AM   #2
tuzzio
tuzzio's Avatar
Post updated.
Old 07-13-2020, 08:02 AM   #3
tuzzio
tuzzio's Avatar
Post updated, just suspension arms left.
