Old 10-07-2019, 01:33 AM   #1
BastosBuilds_S14
BastosBuilds_S14's Avatar
BastosBuilds_S14 is an unknown quantity at this point
Seized sr20det
What’s up guys. So just joined the forum and really wanted to get some input. I just got into the schassis game with an sr but the s14 has a seized? Motor. Reason I question seizes is because the kid I got it from said it started sounding funny so he stopped running it. I towed it home and went to turn the crank and it’s pretty much stuck. Anything I should look at first prior to just ordering a new engine? Or any tips to check on prior to the major year down? Any help is appreciated. Please bare with the newbie
BastosBuilds_S14 is offline   Reply With Quote
Old 10-07-2019, 09:14 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
pull the plugs
make sure the cylinders aren't full of fuel
crank engine
if that doesn't work,
remove the starter and then try to turn the engine over by hand (and by "by hand" I mean, with a breaker bar and socket, on the crank pulley bolt)
if that doesn't work, engine prob has internal damage and will need a full teardown/replacement engine
Old 10-07-2019, 08:24 PM   #3
BastosBuilds_S14
pull the plugs
crank engine
So I tried those and nothing worked. I even checked all pulleys. I checked piston height and they are even. Like in pairs they are even. I put a 3ft breaker bar and got not even a budge. I think I’m just gonna look into a new motor. Maybe chain stuck? Maybe something stupid or real damage? I haven’t drained the oil yet. Wanna see it there’s bits and pieces. Hoping to salvage it but doesn’t look good smh.
Old 10-08-2019, 07:11 AM   #4
S14rebuild
Sounds like the motor is fucked. Pull it out the car, disassemble it to find the root of the problem..either fix it properly or purchase another enine to install
Old 10-08-2019, 11:18 AM   #5
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Don't rule the trans out, could be in neutral, but not really.
Pull all the belts off, pull the starter, and then try, if still no pull the pan and if thats clean, pull the trans and try again.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 10-08-2019, 12:02 PM   #6
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
In all honesty, if its this far along, try to start it and go from there. If the breaker bar won't free it up, the starter will either
1) Free it up
2) Not do shit
Old 10-09-2019, 09:02 PM   #7
BastosBuilds_S14
So I feel like the the trans is fine because it goes into all gears just fine. When I roll the car it doesn’t seem to bind. Or would that matter?
Old 10-09-2019, 09:04 PM   #8
BastosBuilds_S14
I’m probably gonna pull it all apart. If the bearings went bad then it’s still savable right? Depending on how bad the damage is right?
Old 10-09-2019, 11:04 PM   #9
RalliartRsX
Trader Rating: (32)
If its seized, the bearing is your least worry.....
Did you drain the oil and inspect for foreign or bearing material?
Old 10-10-2019, 02:21 PM   #10
S14rebuild
Just pull the motor out, start tearn it down, document everything and see what you find..
Old 10-10-2019, 06:36 PM   #11
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
+1 the confirming trans is in neutral, but youd still be able to turn the motor a little bit if it wasn't, if its that hard to turn its probably fucked
You can drive a valve into a piston and still rotate the motor if you try hard enough only time I haven't seen them rotate is after throwing a rod
The Game
you lose haha
kyral is offline   Reply With Quote
Old 10-10-2019, 06:39 PM   #12
kyral
kyral's Avatar
do what ralliart said and drain the oil. itll be very apparent if it failed catastrophically
The Game
you lose haha
Old 10-15-2019, 01:26 PM   #13
jedi03
+1 tear it down and at the same time order a new engine!
