Old 05-06-2018, 06:06 PM   #1
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
SR20DET Partout - DocRace/PBM/Enthalpy
Prices - Pricing does not include shipping, if you're going to make me a shipped offer please keep this in mind. Some items have wiggle room while others do not, if you try and lowball me don't expect a response, simple as that. I accept payment via paypal, chase quickpay and cash for locals.
Shipping - I tend to ship smaller items via USPS Priority due to the cost, integration with paypal and location as I can drop the packages off on my way to/from work. Larger items will be shipped via FedEx ground, I do not ship via UPS. Due to my work schedule and the fact that I have to pick up these items from my storage unit it may take me up to a week to ship items, please be aware of this.
Local Pickup - Local pickup is preferred, I'm out in brevard county.
Warranty/Returns - All items are being sold as-is, I try my best to describe the item the best I can and I test the function if I'm able to, electronics are powered up and have pictures taken of them in a live state. If you have any questions about the functionality of an item please feel free to ask.
Pictures - I'm getting pictures of this stuff as it comes off of the car, if you don't see a picture here that means I haven't taken it yet.
OEM Bits - I have manifolds and brackets, if you don't see it for sale but know you need to to have a running SR20, I probably have it. Feel free to shoot me a PM.
DocRace V-Band Manifold for SR20 W/ Turbine housing and Tial WG - 1300.00
Manifold is DocRace's OEM location manifold that is ceramic coated, manifold comes with Garrett .86 V-band turbo housing for GT28 turbos. Also comes with TiAL MVS gate and screamer pipe. This is a complete bolt on setup if you already have a GT28 series turbo.
Garrett GT2871R .86 T2 Housing with Internal Gate - 900.00
Low milage and is in great shape, bolt on for S14/S15 motor sets or onto S13 motorsets with clocking adapters, whcih will be included for free if asking price is met.
PBM Cobra Downpipe - 280.00
Downpipe is in great shape, works with the above manifold/turbo setup.
Enthalpy Tuned SR20DET ECU - 400.00
Tuned for GT2871R/740cc injectors/Z32MAF/S4 Cams. Save yourself the downtime of sending out your ECU.
ISR Turbo Lines - 80.00
S14/S15 SR20 Turbo Inlet + Outlet - 80.00
S15 Turbo Oil Drain w/ Hose- 40.00
ARP Headstuds - 80.00
Used but in good shape, one of the nuts is a bit gacked up at the top but the rest of the fastener is fine.
JWT S4 Cams - 400.00
For S13 SR20 only, not compatible with VTC motors.
JWT Adjustable Cam Gear - 50.00
Intake side only.
Tomei Rocker Arm Stoppers - 50.00
Z32 N62 MAF - 90.00
Screens are in great shape and comes with a K&N Filter with adaptor.
DeatschWerks 740cc Injectors - 375.00
Injectors are in good shape other than a little cosmetic marring around the plug when they were removed by the PO. Can include a OEM fuel rail with an ISR FPR delete fitting.
Walbro 400 Fuel Pump 80.00
Used but in good shape, only has about 1800 miles on it.
Wiring Specialties PRO Engine Harness - 500.00
In great shape, this is for a S13 SR20DET in S13 chassis with stock ECU. Has not been modified in any way. Comes with pigtail for Z32 MAF.
Touge Factory S13.4 Valve Cover - 550.00
Professionally done by TF and powdercoated in red with welded on -AN fittings for the vacume/oil return for the block. Comes with AN fittings and lines to plumb back into the block and your intake. More about the service here - http://www.tf-works.com/tf-s13-4-hyb...rvice-sr20det/
Touge Factory Valve Cover Bolts - 60.00
Black in color and in good shape, comes complete.
Invidia N1 Catback Exhaust - 300.00
Has a couple of dings and scratches but other than that it's in great shape. Local pickup only on this item.
OEM Coilpack Covers - 30ea
I have two of these, one in silver the other in black.
TAARKS Power steering relocation bracket - 150.00
Comes with all hardware and belt. Relocates your power steering pump to where the stock AC compressor would sit for more clearance for turbo setups.
ISR SR Ignitor - 60.00
OEM SR20 Alternator - 80.00
In good shape and works great.
OEM Power Steering Pump - 80.00
In great shape and does not leak.
ISR SR20 Replacement Starter - 125.00
Was purchased about two months ago brand new and the car just sat. Starter is pretty much new.
SR20DET Transmission - 200.00
Comes with GKTech short shifter. Local pickup only on this item.
HKS Hyper Single Clutch/Flywheel - 500.00
Clutch is in great shape with a ton of life left.
Koyo Radiator - 200.00
Comes with ISR Radiator Hoses, fins are in great shape. Will need a new drain plug, the stock plastic one is stripped. Local pickup only on this item.
OEM Radiator Shroud - 30.00
Comes with lower guard as well. Local pickup only.
Moroso Oil Pan - 250.00
Used but in good shape, no dents or dings and includes all hardware for install.
SR20DET Head - Offer
Two of the cam cap bolts have been stripped out along with two of the valve cover bolts. Willing to take scrap value on this if you want to try and repair it.
SR20DET Shortblock - Offer
I also have the bottom end that is in good shape, engine had good compression but the above issues with the head led me to part out the car. If you're interested in the shortblock let me know and we can discuss price.
CP Pistons
Eagle Rods
ACL Race Bearings
ARP Rod Bolts
Apexi Head gasket
S14 Oil Pick up
hobbs is offline   Reply With Quote
Old 05-07-2018, 08:57 AM   #2
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
Kallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really nice
Feedback Score: 61 reviews
Lots of good stuff in here
Kallixtos is offline   Reply With Quote
Old 05-07-2018, 07:25 PM   #3
REDBULLDRIFTING
REDBULLDRIFTING's Avatar
REDBULLDRIFTING is an unknown quantity at this point
PM Sent
PM Sent for Valve Cover, Oil Catch Can, Valve Bolts
REDBULLDRIFTING is offline   Reply With Quote
Old 05-07-2018, 09:35 PM   #4
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Do you happen to have the hardware for the coil pack covers as well?
Edit: just reread post
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 05-07-2018, 09:55 PM   #5
mogli9000
mogli9000's Avatar
Trader Rating: (68)
mogli9000 will become famous soon enoughmogli9000 will become famous soon enoughmogli9000 will become famous soon enoughmogli9000 will become famous soon enough
Feedback Score: 68 reviews
nice stuff.
Free bump for you
Straight Outta The Slums of Shaolin
mogli9000 is offline   Reply With Quote
Old 05-08-2018, 07:42 AM   #6
jedi03
glws...this tempts me to get back in the game lol! someone will be happy with this build!
Old 05-08-2018, 09:02 PM   #7
silvia910
silvia910 is an unknown quantity at this point
I pmed you
silvia910 is offline   Reply With Quote
Old 05-08-2018, 11:35 PM   #8
Jfornachon
Jfornachon is an unknown quantity at this point
You don't by chance have a driveshaft?
Jfornachon is offline   Reply With Quote
Old 05-08-2018, 11:59 PM   #9
g_mac530
g_mac530's Avatar
g_mac530 is an unknown quantity at this point
Send a message via AIM to g_mac530
Sent you a pm
Originally Posted by RoXiE.S14 View Post
Because Jesus himself made the nissan 240, true story
g_mac530 is offline   Reply With Quote
Old 05-09-2018, 12:46 AM   #10
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
getting rid of the heat shield?
240KA is offline   Reply With Quote
Old 05-12-2018, 12:21 AM   #11
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
pm sent
msgs lnght
Old 05-19-2018, 01:40 PM   #12
hobbs
Trader Rating: (43)
Yup, shoot me a PM.
Old 05-20-2018, 10:43 PM   #13
wangan_cruiser
kouki man
Trader Rating: (36)
you never got back with my pm. whats up?
Old 05-22-2018, 07:28 PM   #14
hobbs
Trader Rating: (43)
Bump to the top, sold items removed.
Old 05-25-2018, 07:39 AM   #15
hobbs
Trader Rating: (43)
Bump, FPR and catch can sold.
Old 05-25-2018, 08:07 AM   #16
Little Jason
Little Jason's Avatar
Little Jason is an unknown quantity at this point
sent PM about the wiring harness.
Little Jason is offline   Reply With Quote
Old 05-25-2018, 11:07 AM   #17
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Cool parts. PM in bound.
Old 05-31-2018, 01:37 PM   #18
1gr8bar10der
Trader Rating: (77)
Payment sent for the Splitfire.
Old 05-31-2018, 02:53 PM   #19
hobbs
Trader Rating: (43)
Coilpacks sold!
Old 06-01-2018, 07:50 PM   #20
JC831
JC831's Avatar
JC831 is making a name for him/her selfJC831 is making a name for him/her self
Pm sent on CAS
JC831 is offline   Reply With Quote
Old 06-05-2018, 08:36 PM   #21
hobbs
Trader Rating: (43)
Bump to the top.
Old 06-27-2018, 07:50 AM   #22
hobbs
Trader Rating: (43)
Bump to the top!
Old 07-07-2018, 08:16 AM   #23
hobbs
Trader Rating: (43)
Bump to the top!
Old 07-11-2018, 08:40 AM   #24
Apanda
Apanda is an unknown quantity at this point
Pm me pics of the z32 maf with intake set up your selling with and also info on the rocker arm stoppers
Apanda is offline   Reply With Quote
Old 07-11-2018, 09:07 PM   #25
smoketherear
smoketherear is an unknown quantity at this point
Any possible way you would ship out the shroud?
smoketherear is offline   Reply With Quote
Old 07-12-2018, 02:16 PM   #26
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
Sent you a pm for the splitfire and the cas.
roninwon is offline   Reply With Quote
Old 07-14-2018, 07:18 PM   #27
hobbs
Trader Rating: (43)
Old 07-15-2018, 05:11 PM   #28
Sr24
Sr24 is an unknown quantity at this point
Do u have a cold air intake that will clear the power steering pump?
Sr24 is offline   Reply With Quote
Old 08-05-2018, 03:19 PM   #29
hobbs
Trader Rating: (43)
Bump to the top.
