![]() Join Date: Aug 2008
F/S 1993 240sx vert w/ gt2871r sr20det and cage
ok, ive debated doing this for about a year, and now is the time to bite the bullet and get it over with. I simply don't have time to drift anymore.
Heres a parts list and price: Motor: S13sr20det Fully rebuilt ACL Bearings ARP head bolts HKS Head Gasket HKS Rocker Arm Stoppers Isis Exhaust Manifold Isis Outlet Pipe Megan Down Pipe gt2871r turbo HKS Wastegate (spring is at 14lbs, tune can easily handle 17lb spring) HKS SSQV Blow Off Valve 14lbs 555 injectors Big Aftermarket fuel rail 300zx FPR Freddy Intake Manifold Mid Mount intercooler eBay radiator with dual fans Aftermarket hoses Aluminum pulleys 300zx MAF JWT tuned ECU SPEC stage 3 Clutch Lightweight flywheel Interior: Full legal roll cage built by nocturnal motorworks. Allows the convertible top to be closed over the cage. Awesome fab work. even goes through dashboard 2 racing seats. kinda dirty but this is a race car.... Dragonslayer harness on drivers side, ebay harness on passenger Isis hydraulic ebrake (Stock ebrake is still intact, just not hooked up) REAL LEGIT Nardi woodgrain steering wheel in great condition Greddy weighted shift knob harbor freight boost gauge Fire Extinguisher Suspension bits: Stance GR+ Coilovers Megan Rucas Megan Tension Rods Tein Tie Rods Tein Tie Rod Ends Misc Parts 300zx Master cylinder swap 300zx rear breaks EBC brake pads Conversion Lines q45 Front brakes upgraded pads Megan racing 3" exhaust (sounds great) Origin knock-off Tail lights (all lights and turn signals work on the car) Wheels: Heres where it gets interesting. I have 8 elite 17x9 +15 wheels, 4 Rota p45r 17x9 +17 and 4 Rota p45r 17x9.5 +17. I dont know which ones i want to go with the car, probably the rota's, because the elites are so rare. 2 of the rotas also have FRESH red smoke tires on the, 255/45/17's, and this car had no problem spinning them. If you want to buy the car, we will figure out what wheels to give you. Stuff that needs fixing: -the hyrdo ebrake could use a better mounting job, along with the drivers seat. both were a rush install for an event (pics below). -windshield is cracked but i still passed tech at the event i went to -I cut out the rear window, the ones that came with these cars were just shit. I have the clear vinyl material to replace the window, which you can have if you get the car. -rear bumper has a slightly pinkish hue from the red smoke tires. i got most of it off but you will probably need to rattle can the rear bumper. What makes this car so great - did a compression test to test the motor before selling. awesome numbers across all 4 cylinders, none were low. - streetable tune, which means you can drive this beast on the street and rip at the track - has a screamer pipe on it, so its LOUD - its a vert with a fully built sr20 in it. i mean, come on, what more could you want? Pics and video: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() PRICE: 7000 without wheels, 7500 if i add the wheels. dont low ball me or i wont respond. thanks
TEAM GET MONEY>>> getmoneydrift.com Last edited by REVOisGO; 04-13-2013 at 02:32 PM.. |
240, cage, drift, sr20, vert |
