09-21-2019, 09:40 PM | #1 |
First project going terribly need guidance
Okay guys, bought a 240sx off Craigslist that ran like complete shit but I didn’t know anything about cars at the time. Fired on like 2 cylinders and couldn’t idle, backfired constantly and, arrived at my house with a cut open header, wires running to the wrong plugs, I make a tiny check and all my time and money been going into driving this on the road one day
I did work and research over the past 6 months to get this car running nicely, it runs good in IDLE, I can step on it and it will go back to good idle and stay idleing with decent response, little to no misfire BUT AS SOON AS THE CAR MOVES A FOOT FORWARD OR BACKWARDS IN GEAR IT INSTANTLY SHUTS OFF Is their something DIRECTLY linked to the car moving that could cause this? It’s so annoying as soon as I think it’s time to drive it after replacing a random part every fucking pay check just to have it die after 5mseconds of moving it’s killing me inside Sohc ka 240sx 1989 Last edited by Presto; 09-21-2019 at 10:27 PM.. |
09-21-2019, 09:44 PM | #2 |
bought headers but didn’t fit right, hammered it in so the steering rack doesn’t grind it so it gets pretty narrow off one cylinder a couple feet down the header
Bought injector rings, but ripped them on installation, replaced them again Bought all new injectors, one didn’t work right, + fuel rail stripped, had to fix that Bought new o2 sensor, but connecting wire looks fried, still plugs in and seems to work Bought tps, but multimeter can’t get reading for calibration so I just have it to the right from when I put it in Bought coolant temp sensor connector and soldered new one in Bought a reman maf sensor, but still have intake hissing Bought a new air cleaner, but still have intake hissing Pulled out the fuel pump, fixed a wire, but could still be having fuel problems Last edited by Presto; 09-21-2019 at 10:21 PM.. |
09-21-2019, 09:46 PM | #3 |
Replaced iacv gasket/ cleaned iacv, but still have vacuum leak possibly somewhere
Adjusted idle as low as possible, but still have high idle like 1000-1100 Bought bolts to plug holes on intake manifold, but bolts are too long/poke out Ripped the spark plug wire so replaced all ignition wires |
09-21-2019, 09:47 PM | #4 |
Reset distributor 5 times, but timing still completely off no matter how I do it
Previous owner did emissions delete / egr block off plate seems to not be leaking Compression test said each cylinder was at 120 exactly so that’s fucked Searched vin number and it said in mechanics notes that engine caught on fire at some point One of the coolant hoses under the intake manifold is KINKED Injen aftermarket intake Car starts up every time first try though Last edited by Presto; 09-21-2019 at 10:27 PM.. |
09-22-2019, 01:21 AM | #6 |
Trader Rating: (130)
Feedback Score: 130 reviews
Sounds like you have a LONG list ahead of you. Fix the easy shit first, like the kinked hose under the intake manifold.
If your compression is that low, you got bigger issues. |
09-22-2019, 01:40 AM | #7 | |
Also I put tape over the intake to make it run alright haha If this ends up bad, What is a cheapest engine besides another SOHC (s13 coupe) |
