Old 01-19-2015, 07:40 PM   #1
Mfabsr20
Mfabsr20 is an unknown quantity at this point
clutch pedal won't pop back up.
Please no flaming, I have searched the forums for my issue, and have pretty much figured out what the problem is. I would like to just know if anyone else has ran into the same problem.
When I drive my car normaly, everything is fine. I am able to press down on the clutch, and it pops back up smoothly. The problem is when I am driving the car hard, the clutch pedal will not pop back up, and I have to physically lift it with my left foot. Now, this isnt primo. I have bled the clutch multiple times, and still the issue persists. Through my research, I can only come up with that the clutch master, and/or slave are worn out and need to need replaced. So I am just go to replace both. I will check back after I install them to see if that remedied the problem.
If anyone has any input, it would be much appreciated.
Mfabsr20 is offline   Reply With Quote
Old 01-20-2015, 07:05 PM   #2
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
you pretty much solved your problem.
Im definitely going with bad clutch master.
Javi802 is offline   Reply With Quote
Old 01-20-2015, 07:34 PM   #3
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
there is either still air in the system, or u need to adjust the clutch pedal under the dash. it is very hard to get all the air out with the factory clutch dampner box if u haven't removed it already. to get all air out, u need to push the clutch fork all the way in by hand when bleeder released and retighten bleeder b4 releasing it while someones holding the pedal down. hope that's of some help
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
r20crazy is offline   Reply With Quote
Old 01-20-2015, 08:13 PM   #4
Javi802
Javi802's Avatar
And if you do still have the damper, just go ahead and remove it. Its simple.
And to reiterate what he said...
After removing damper and connecting it all back together
fill master cylinder up with brake fluid, leaving lid off
pump the clutch pedal several times and on the last pump, hold the pedal down.
Then you or somebody else, loosen the bleeder valve on the slave, letting air escape. (its best to have a clear hose connected to the bleeder valve, so you can see whether or not air is coming out.)
Close bleeder valve and repeat this over until no air is coming from hose. Only fluid
Old 01-22-2015, 06:43 PM   #5
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Brake/clutch fade.
Are you N/A or boosted?
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 01-22-2015, 08:14 PM   #6
Mfabsr20
N/a....bone stock ka
Old 01-22-2015, 08:40 PM   #7
!Zar!
!Zar!'s Avatar
Did you even change that stuff yet?
Old 01-22-2015, 08:47 PM   #8
nick Ritter
nick Ritter is an unknown quantity at this point
i had similar problem awhile bcd on one of my swaps ended up being a sticking throwout bearing
replace those 3 things and you'll be golden !
nick Ritter is offline   Reply With Quote
Old 01-24-2015, 10:59 PM   #9
Mfabsr20
Thank you for everyones input....
So, today I was able to address the problem I was having. After getting the car in the air, the first thing I did was take the dust shield off the transmission. I was looking to see how the clutch was actuating. Primarily looking to see if the throw out bearing was sticking anywhere. It works smooth, just like it should. I figured at that point my problem was definitely the clutch master and/or slave cylinders. In about an hours time, with the help of a buddy; the install of a new clutch master and slave cylinders was wrapped up. After doing the necessary bleed of the of the system. I am happy to report that the clutch pedal has better feel than it ever did. Doesnt get stuck in the floor, and clutch kicks like a boss...
Old 01-31-2015, 07:33 PM   #10
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
i have the same issue, sr20 tho, replaced the master and slave already and still sticks at the bottom, clutch works still but pedal only moves and inch max
HellaSexyS13 is offline   Reply With Quote
