Old 11-11-2012, 11:45 AM   #1
wadhah
wadhah is an unknown quantity at this point
** Calling all the SR20DET experts...need help**
just swaped an sr20det redtop on my 240sx 91 fastback s13 with ka24de and now im missing a part
NOOB ALERT!!
if u guys see the pics attached im missing the part that fits the empty socket , the other pic has the missing part installed on the socket ( got it from a my old ka24de ) and the engine started fine didnt drive it though.
whats the name of the that part and if possible the part number.
im just afraid the old part wont work perfectly or damage sumthin later on!!
Thanks guys
wadhah is offline   Reply With Quote
Old 11-11-2012, 03:50 PM   #2
jr_ss
Better pictures would be nice. I think a wider shot, not so zoomed in, on the area so we can see what it may go to.
Old 11-12-2012, 12:01 AM   #3
Mikester
Mikester's Avatar
I am almost finished putting my SR together after a fresh rebuild... Never seen that part before. Probably only applies to the KA. The only thing that looks even remotely like that on the SR is the TPS (throttle position sensor), but that's up front on the throttle body. What harness are you using?
Old 11-12-2012, 12:12 AM   #4
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
That first plug looks like the coil pack plug or maybe the 02 sensor I can't tell from the dim light and blurry pic.
SLiDe_WaYz is offline   Reply With Quote
Old 11-12-2012, 07:36 AM   #5
wadhah
im using sr harness
Old 11-12-2012, 10:24 AM   #6
Raycampos
Raycampos's Avatar
Raycampos is an unknown quantity at this point
Its the throttle position sensor
Raycampos is offline   Reply With Quote
Old 11-17-2012, 02:36 AM   #7
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
It's not the throttle position sensor although it looks similar. Its what I've always heard it being reffered to as an ignitor chip back when I had a gti-r swapped into my g20. It's not needed for an SR as they have coil packs instead of a distributor and coil. So get rid of it and move on. An sr fsm for your motor would help you out.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 11-17-2012, 08:18 PM   #8
SLiDe_WaYz
SLiDe_WaYz's Avatar
Uhmmm the igniter chip is for your coil packs.... Car won't start without one bro.
