09-01-2008, 07:23 PM | #1 |
car shakes violently. help?
so i got this fastback. its a 92. dohc ka. prev owner said it has nismo mounts, i cant confirm that. at idle the car shakes like it has a bigblock in it. once i bring the rpms to about 1500 it stops shaking. any ideas?
09-01-2008, 07:42 PM | #6 |
get a new cap and rotor, new wires and plugs, check the vacuum hoses and verify that your timing is correct. should fix your problem.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
09-01-2008, 07:46 PM | #8 |
should take about an hour to do. did it on my friends s13 kae and it worked wonders. cost 50 bucks.
09-01-2008, 07:52 PM | #10 |
well, you should check the timing first. why? because it's free if you already have a timing gun. also, you may have a leaky injector. but 50 bucks for a tune up is cheap and should be done anyways.
09-01-2008, 07:59 PM | #13 |
09-01-2008, 08:13 PM | #15 |
id love to find out.
also, the cars shifter is very sloppy. i put it into first and it looks as though its in neutral? the prev owner told me its a bushing. i havent looked into it |
09-01-2008, 08:29 PM | #16 |
Nismo mounts aren't any stiffer through the chassis so there's no reason to think that's the problem. Besides, a stiff mount would cause NVH throughout the rev range, not just low speed.
Vacuum leak, incorrect timing, or a misfire is the culprit.
09-01-2008, 08:35 PM | #18 |
ill check it out and update.
ill be doing a tune up and ill check for vacuum leaks and the timing. my old man says he has a timing light. and ill check the mounts too. |
