03-01-2012, 08:15 AM | #4622 | |
Why no thoriated? And why no lens on Al? |
03-01-2012, 12:19 PM | #4623 |
Thoriated is garbage. It's a nice all-purpose tungsten if you're using an inverter TIG and have nothing else to use. I like the arc consistency and stability of Lanthanated (preferably 1.5% over 2%) and Ceriated.
And there's absolutely ZERO need for a gas lens on aluminium... I welded aluminium for 6 months straight at an old job. 12 hours a day. Thicknesses ranging from 1/8'' to 1.5'' thick. I tried ever regular cup size available and every gas lens (Company stocked so much stuff). Using a gas lens made ZERO difference. The best cup I found was a regular old #5. |
03-01-2012, 10:32 PM | #4627 |
Its hard to see but in most areas it was just about poking through, I just smoothed it out a bunch before it got coated. Sch40 is thick, 100% pen everywhere wasn't my biggest concern personally
03-02-2012, 06:33 AM | #4628 |
This type of mentality makes you look like a sloppy fabricator. I was trying to be nice and help you, but that type of attitude makes me rage....
03-02-2012, 06:49 AM | #4629 | |
(now waiting for flaming and authority argument, but dont waste your time, i dont really bother about that) |
03-02-2012, 08:14 AM | #4631 | |
My issue with Thoriated is the spitting. After some usage, the tip gathers splinters of tungsten at the tip. I'm sure you've noticed it. Those splinters spit off into your weld (and also cause arc wander etc). Now it's not going to create any serious problems, unless you x-ray it. Maybe I'm just picky and a perfectionist when it comes to welding... |
03-02-2012, 08:37 AM | #4632 | |
I have used Ceriated on thin sheet metal but have never compared Thoriated back to back, but yes I hate when Thor freaking splinters. Next time I get supplies I'm going to try Lanthanated. |
03-02-2012, 09:38 AM | #4633 |
I personally like 1.5% Lanthanated (Gold band) the most. Especially on stainless steel. I feel it's very very stable and the puddle just feels so fluid and natural.
Ceriated is a very close second. Then 2% Lanthanated. I really want to try the hybrid tungstens. |
03-02-2012, 02:29 PM | #4634 | |
i never have and ive never had a single problem what so ever i like having the inside of my collector to have sharp joints and penetrating or welding the inside would not give me that result |
03-02-2012, 04:46 PM | #4635 |
Again, to me it just shows laziness/sloppiness.
You may not think it's necessary but I strive to do the best work I possibly can. That includes tying up loose ends. Such as the other side of weld joints. Kudos to you if you don't. Again, I won't promote someone to do sloppy work. |
03-03-2012, 02:04 AM | #4636 | |
the reason i dont do it is because it would not give the sharp joints im after if i lay a bead on top of the joint inside the collector ill end up with a rounded joint instead of the sharp joints im after anyways this is the latest car im working on GT3076R custom high mount turbo blah blah blah u get the picture Last edited by STR8E180; 11-26-2012 at 02:04 AM.. |
03-03-2012, 10:39 AM | #4638 |
Here's my exhaust manifold with cast T4TS collector and the solid aluminum engine mounts me and my boss made. I'll probably re-do the mounts, the aluminum I used was contaminated or something, it was weird.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 03-03-2012 at 01:44 PM.. |
03-03-2012, 01:43 PM | #4641 |
DSM 7-bolt 4G63 good sir. Will be a 2.3 stroker.
03-03-2012, 01:53 PM | #4642 | |
What's wrong with the rounded edges anyway? Do you think sharp edges equal better flow? Poorman. I'm on my phone but those aluminium mounts don't appear to look contaminated... :s |
03-03-2012, 02:10 PM | #4643 |
Hahah, the other one is a little worse, think they'll hold? I am probably going to redo them in steel so they look nice and I don't have to worry about them.
03-03-2012, 06:40 PM | #4645 | |
I don't know how much experience you have with aluminium, but 100% PERFECT fitment is everything. |
03-03-2012, 10:06 PM | #4646 | |
Patrick, I know I know, but really it's a much more practical engine than the SR or KA for what I'll be doing, plus the ability to use a T56 trans is a plus.
03-06-2012, 12:25 AM | #4650 |
You, fab guys got any samplepics of good tube front ends? I am in the process of having mine done and want to see some different examples to decide which one is best for me.
Thanks ahead.!
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
