Old 04-30-2020, 12:47 PM   #1
RobbieSS
RobbieSS is an unknown quantity at this point
Injectors not getting power help
Hello zilvia lads, I am once again requesting your support lmao. So i'm having issues getting my injectors to work correctly. I have fuel in the fuel rail and the fuel pump is priming. I took a multimeter to my injector #1 harness cable and i read resistance but when i went to dc It only read 150+ for some reason. This is with the key in the on position. I thought it could be my ignition chip cause it wasn't reading any continuity but that didn't work. I have a feeling it might be my ecu which would suck so hard
RobbieSS is offline   Reply With Quote
Old 05-08-2020, 07:10 PM   #2
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Fuel Injector wire should be reading 12 volt while ignition turn on. Check the fuses if working. It can be bad ecu, engine harness, distributor or injector.
kennedy8383 is offline   Reply With Quote
injector
