08-20-2010, 10:08 AM | #1471 |
Everyone has different driving style, most guys also don't run 295s up front anything that can make the front come alive more/be more responsive = welcome. Also I am going with that custom manual steering rack setup from the nico group buy. So faster = win. I think HICAS rack is too slow, the non-hicas sucks ass.
08-20-2010, 10:24 AM | #1472 |
Hicas rack = 2.5 turns lock to lock.
Standard rack = 3 turns lock to lock. Standard rack + PSM SAK = 2.5 turns lock to lock. (On close hole) Hicas rack + PSM SAK = 2 turns lock to lock. 295's and a manual rack? Sounds like you're going to be getting a work out.
08-20-2010, 11:46 AM | #1475 |
Your car is 1.5 turns from all the way left, to all the way right?
08-20-2010, 12:03 PM | #1477 |
Hahaha, yeah, that's what "lock to lock" means.
You probably have 1.25 each way, which would be 2.5 "lock to lock". At least that's what PSM says it should be.
08-20-2010, 12:32 PM | #1478 |
The steering response and weight changed drastically when I changed from a 235 to a 255. I cant imagine what a 295 would be like.
08-20-2010, 12:47 PM | #1479 |
Just found this pic. GT300 s15
Coilover mounts on this thing are crazy. More pics on gt300.no if anyone wants to see more. They have pretty detailed pics of everything on that car. |
08-20-2010, 01:06 PM | #1480 |
That's called a pull rod suspension setup. The rod going from the upper a-arm "pulls" on a bellcrank that gives a different motion ratio to the damper. Pretty trick space frame setup up front.
08-20-2010, 03:58 PM | #1482 | |
1. FLCA needs to be really long after you alter the roll center because the knuckle's LCA mount angle puts the LCA end joint towards the brake rotor. 2. if you reduce the ackerman your tie rod has to be much longer, customers say their tein tie rods dont work with our SAK. Ikeya formula rods are long enough and our new less expensive then ikea rods are very long (and cheaper) If you pair aftermarket rod ends they better not have any spacers on them, so we just prefer OEM s14 spec. 3. If you space down the LCA knuckle mount using the OEM KPI you cant go more than about 25mm. If you want more, you have to change the KPI angle to be more vertically oriented to clear the brake rotor. 4. If the ackerman is too low you will hit the tension rods. 5. Correct but hitting the wheel on things is easily helped by adding a wheel spacer. (I had to add 20mm on my old setup to accomodate the new angle, and I dont hit the tie rod, or frame, and the brake bracket can be easily moved by using one bolt to mount it. We dont have them for sale yet but will very soon, thats the pic of the production quality prototype MAX original tie rod we are testing now. Super F'ing long and strong but in a collision situation you are covered because the factory has tested bending them in 180 degrees without breaking and we're going to have a great price on these. here is view of the rear. you can see that with our sway bar mounted so high it will keep the maximum ground clearance for the bottom of the link a view with the car on the ground and finally the front while on the ground .........as far as dialing in our parts for grip and setting up the knuckles for only faster steering and not more angle its really no problem at all. We'd be happy to do it that way if you wish, just need to specify your desired use when ordering the knuckle service. = )
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-20-2010 at 07:42 PM.. |
08-20-2010, 04:10 PM | #1483 |
You guys keep using the term kingpin inclination for why the arm runs into the brake rotor. That doesn't really have anything to do with it, since the KPI is an imaginary line from the top strut pivot to the lower ball joint. The ridiculous angle relative to horizontal that the stock uprights have for the ball joint mount is the problem. It's at a far more aggressive angle than the KPI is on a lowered car. Maybe it's closer on a sky high stock S chassis, but I tend to think of that as one of the engineer's goof's on our suspension.
08-20-2010, 04:28 PM | #1484 | |
Turn and Burn! |
08-20-2010, 05:19 PM | #1485 | |
I would love to get these PBM arms but I'm quite tapped out and my setup works just fine after I got all the links out of it. Going to be working on the passenger side all weekend so hopefully I will have a report on these soon for you guys. |
08-20-2010, 07:36 PM | #1486 | ||
what you described as KPI is the steering axis line? I dunno what you want to call that taper rod angle (is there a better term?) but im sure you all understand It looks like it follows the steering axis or KPI angle more or less to me. I suppose the above statement could be changed to say 1. FLCA needs to be really long after you alter the roll center because the knuckle's LCA mount angle puts the LCA end joint towards the brake rotor. Quote:
yes they can be used with an unmodified knuckle.
08-20-2010, 08:23 PM | #1487 |
I have mad respect for PBM and what they are doing, they are developing parts that will benefit us all. I felt the same when Kuah was on the frontline of putting out quality products, but since seeing this stuff from PBM I am sold. I mean at first I was like meh more shiney jdm parts... but this... this is something else
My other concern I'd like to address is scrub radius, as I have mucho grande low offset/wide front wheels... Overall all this is quite promising woohoo |
08-20-2010, 08:32 PM | #1488 |
Trader Rating: (24)
Feedback Score: 24 reviews
i love this thread so much but at the same time i hate it cuz im broke
btw im looking for someone than can do me a favor. for my S13, looking for someone to fab front and rear control arms wit 3/4 spherical bearing. PM me priced shipped. if you have some extra arms laying around that way i dont have to send mine. like what i said im broke so if you know what i mean and help a brotha out.
REVIEW |
08-20-2010, 10:07 PM | #1489 | |
Trader Rating: (58)
Feedback Score: 58 reviews
08-20-2010, 10:53 PM | #1490 | |
08-21-2010, 09:51 AM | #1491 | ||
Also depending on how things go, I might opt for the column mounted EPS option, also available from the same company. They've put it together. It won't destroy feel or anything and it's speed sensitive, so only when needed will it become active and can be turned off. Shouldn't decrease any of the quality of feedback, control, precision. Again totally different ball game than slush fluid. This should be fun hehe. I'll only need a steering wheel like this lmao, who wants to turn pshhh : Then all I'll need is an electronic differential lool Quote:
08-21-2010, 11:02 AM | #1493 |
^Cool
And this is a nice link!: Wheel Alignment Explained I was reading it and it kind of opens my eyes a bit but I am still trying to fully understand what will be the better or ideal setting with larger tires with a lower offset on our cars. From what I understood running more negative camber from the upper strut mount would alter the scrub radius, and then of course lower or higher offset... and adjusting camber from the LCA/spindle? |
08-21-2010, 05:32 PM | #1494 |
Dan, the parts look really good. Are you on 18's up front? Looks like you have room for the 25mm shank as far as the wheel goes?
And for the rear, it doesn't look like you're going to be able to combine the drop knuckles with the 25mm adjuster lower shanks eh? Pretty close to the wheel already.
08-21-2010, 06:38 PM | #1496 | |
I can't wait for you to get these done; waiting patientlly |
08-21-2010, 09:16 PM | #1497 |
They're 95% designed. I've just slowed down on it as I don't know if there's much of a market there. But I guess I'm almost done, so I might as well finish it up.
BTW - projected weight savings in just the upright is about 4-5 lbs(need a more firm weight on the hub I'm using to nail it down).
08-21-2010, 10:14 PM | #1498 |
Is is still going to be a combo with a FLCA, or just the knuckle/hub combo?
