12-15-2010, 08:06 AM | #2221 |
Running no rear bar helps the rear wheels move a bit more independently, thus able to find grip better on their own.
But like many have said, it really depends on their driving style, and what they car is setup to do. I currently don't have my front sway bar connected, but wish I did. The rear sway bar is connected (S13 HICAS bar) but I'm using stock endlinks. I need to find some other end links because they are oriented in a sort of weird way, since the rear LCAs are I think meant for an S14. |
12-22-2010, 03:18 PM | #2222 | |
Im glad you guys are thinking in an intelligent way about dealing with caster adjustment pros and cons. We have been in development and testing for a whole year on this. We are about to release our new pro coilovers with caster adjustable top plates (among many other cool features) next month. I've been keeping a lid on the design but since you guys had it on your mind lately, I'll let you know its damn close to release. you can leave the lower mounts alone if you use a wider lower control arm to get more camber.
12-22-2010, 09:29 PM | #2223 |
I have a quick question that i guess is not so off topic. On my '90 S13 hatch im running all adjustable arms front and rear,also better inner and outer tie rods, Except no adjustable lower control arms(i did reinforce my stock front and rear lower control arms and using polyurethane bushings in my lowers and on my stock front knuckles) In the rear im also using Z32 rear knuckles on their stock bushings. Im using Fortune Auto coilovers with the optional swift springs. My subframe in the rear is also slightly raised using SPL aluminum subframe busshings and spacers. I dont know why but i havent purchased performance swaybars yet. Im using 17" wheels.Very basic compared to the setups you guys are running. Im just getting into the drift thing,finally,and im just trying to get on the right track with suspension(as a beginner). How low can i go safely without any binding in my suspension and without damaging anything? Its going to be street driven and hopefully i am going to enter some amateur practice sessions. Also what would you change on the car in my situation? This thread is the bomb by the way...Thanks in advance guys.
12-23-2010, 07:36 AM | #2224 |
It's all driver preference man. What I like about my suspension, you may come along and go "this is complete crap" and walk away in disgust.
Ride height, especially, is definitely a driver preference thing. You may like how the car drives at a slightly higher ride height (what most Zilvians call a 4x4 ride height), or you may like how it feels better slammed. Once you get the car to the ride height you want, then you can check for binding. Usually this is pretty obvious. When you have your ride height set, just put the car on jack stands and take the coilovers out on the rear, then jack each wheel up till they can't go no more, and then check to see if your suspension arms and wheels are clearing everything. If so, good to go, move to the front. In the front, take the springs off of the coilovers and bolt it back on, then jack the wheel up via the lower control arm, and see if you're hitting anything at either lock. That's about as simple as I can make it. |
12-25-2010, 02:27 AM | #2225 | |
12-25-2010, 09:18 PM | #2226 |
dan all im caring or giving a damn about at the moment is those LCAs and drop spindles front and rear and if you could make the rears z32 style and of course all spherical heh
12-30-2010, 10:36 AM | #2227 |
powers did alot of changes this season that paid off well for him...... these shots gives a nice look at his control arms
full lock diff
12-30-2010, 10:40 AM | #2228 |
my control arms are stock. i feel like my setup still sucks. its gonna kick some serious ass next year though. the rear is getting better though but i have sick ideas on that for next season as well
driftparty.com |
12-30-2010, 12:29 PM | #2230 |
yup, he raised it. being slammed doesn't make it a competitive car. looks like hes not going to run his KA-T setup for 2011 neither.
Dan- i heard new coils will run swift springs and you guys are releasing coils for the Z33 also? |
12-30-2010, 12:32 PM | #2231 |
12-30-2010, 12:43 PM | #2232 |
Pretty sure the rears would work, just judging by that picture and knowing how the S13 Sway bar attaches to a the LCA.
12-30-2010, 02:01 PM | #2235 | |
I would also imagine your steering is a bit weird from your tie rod ends being like an inch below your ball joints. The knuckle mod would fix both of your problems.
12-30-2010, 02:24 PM | #2236 |
im still deciding what im going to do for knuckles next year. I think im going to run adjustable tie rod ends and lower control arms for bump steer and roll center instead of having it all done on the knuckle. still considering my options though.
driftparty.com |
12-30-2010, 03:04 PM | #2237 | |
12-30-2010, 05:19 PM | #2238 | ||
The LCA 's are next, maybe released in march. They will certainly be different (better) than prototypes I have shown here. Right now we are making new forging dies for a new type of rod end and rod end receiver specially designed specifically for LCA duty. The rear knuckle is the final frontier, it certainly will be full spherical. Quote:
All of the new pro series coilovers will come with swift springs. Z33 will only be available only in the pro version and will be released mid february along with S13, S14 and Genesis applications. Z33 coilovers will be coil-over-damper instead of separate coil and spring in the rear. We are also currently in development of a complete multilink solution for the Z which will have ~straight tubular rear lower control arms (instead of the OEM spring boat) ~rear traction rod ~rear toe rod Front end of the Z33 will be ~single pivot camber adjustable FLCA with spherical shock mount and caster adjustable compression rod combo ~bolt on super angle knuckle adapter ~tie rod, tie rod end, and rack position spacer All of the front end items will need to be purchased together since they are all designed around each other as a complete conversion front end, but the result is up to 60 degrees of angle and a super flat tire patch at full lock.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 12-30-2010 at 06:16 PM.. |
12-31-2010, 02:14 PM | #2240 |
12-31-2010, 03:18 PM | #2241 | |
That sounds amazing. |
12-31-2010, 03:19 PM | #2242 | |
Here are some pictures I just took, does the tension rod looks like its installed incorrectly? Now looking at it, it does look off to me. Wish my alignment guy would have mentioned it to me. Heres the tire/firewall clearance at 90% lock. I can barely squeeze my finger in there. Right now its at 9.2, if I lower the caster, wouldnt it be even closer?
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
12-31-2010, 05:00 PM | #2244 |
Your car is just too damn low. And 9.2 caster is quite high, Make the tension rods stock length
Nothing says racecar like a stock car with no interior. |
12-31-2010, 06:30 PM | #2246 |
Looks like that locking nut on the rear is supposed to be butted up against the aluminum part that mounts to the LCA, not tightened at the end of it's threads in the front.
12-31-2010, 07:07 PM | #2247 | |
Amazing what a little proper setup can do to a car.
12-31-2010, 07:17 PM | #2248 |
the quick answer to roll center correction? Just dont lower your car so much, and it will actually handle. But seriously though i have my control set to where they are parallel to flat ground, thinking about raising it up just a hair. Not sure where it is optimal
12-31-2010, 07:18 PM | #2249 | |
12-31-2010, 07:19 PM | #2250 | |
good eye i didnt even notice.
