07-07-2015, 10:12 PM | #1 |
S14 Partout Engines Other Items Moving Sale
I'm going to be moving soon and i have a ton of spare parts and things i need to get rid of most of what i got listed here is what i have ask for anything else.
GAS TANK NO CRACKS READY TO SHIP Blower Motor Condenser Fan Control/Heater Core Unit Door Stainless Steel Trim and Seals Drivers Side SOLD Dashboard MINT no cracks or tears still soft but deployed passenger airbag AC Compressor Line Low Side B Pillars MINT C Pillars MINT Trunk Latch and Metal Springs Clean Title and Numbers SOLD Front subframe with Steer Rack S14 Knuckles with ABS Sensors SOLD Stagg Struts with OEM Springs Front and Rear <1500 miles SOLD OEM Stock Rear Calipers SOLD Front Lower Control Arms OEM Tein Tie Rods SOLD OEM Steering Rack Good OEM Gas Tank With Walbro 255LPH Pump SOLD Engine Harness With Fusebox SOLD Window Switches Drivers and Passenger Plus Window Amp Working Drivers and Window Amp SOLD 300ZX 30mm Iron Calipers with Steel Braided Lines and Drilled and Slotted Rotors Rear Drilled and Slotted Rotors Stock SOLD Entire rear subframe with god speed Control arms toe and camber and entire rear has poly bushings installed with knuckles and Factory VLSD. SOLD MB Battles 17X8 28 Offset 5x114.3 MB Motoring Weapon Gun Metal with Fresh Hankook Ventus V2 Concept H437 225/50 R17 <3000 miles SOLD OEM Brake Master Cylinder And ABS Brake Booster Brand New Exedy Clutch/Slave With Braided Steel Line SOLD Pedal Assemblies Clutch SOLD. BRAKE AND GAS PEDAL AVALIBLE Rear Seats MINT SOLD Drivers Side Front Seat Interior Door Panels MINT Only Passenger Available Trunk Floor Carpet SOLD Main Carpet SOLD Rear Window Speaker Cover SOLD Trunk Side Wall Carpet SOLD Spare Tire Jack SOLD Headliner MINT Sun Visors Rear View Mirror Doors Complete with Harness Glass And Motors Bolt On And Go Trunk Lid SOLD Tail Lights Rear Bumper Side Windows Passenger side SOLD Dash Harness SOLD Dash Switches/Cluster 197k miles SOLD Steering Wheel Plastic Cover SOLD Window Wiper/Turn Signal Handles SOLD Glove Box Fan Motor For Heat And AC 1-4 Working Perfect Vents/Anything Under The Dash Mass Air Flow Sensor OEM SOLD Center Console mint Rubber shifter boot and metal ring SOLD Stock shifter trim,knob, new leather SOLD Rubber boot for E-Brake SOLD AC Bezel with all buttons no cracks or scratches or broken tabs SOLD Radio trim with ash tray and 12 volt port. All but 1 tab where the ashtray is are broken and there is a crack on the right side. SOLD Climate control unit working with lights. Rockford Fosgate Mono Block Amplifier R500X1D Rockford Fosgate 4 Channel Amplifier R300X4 Rockford Fosgate 4x 6.5 75rms each speakers Rockford Fosgate R2 12" Subwoofer 250w RMS A Pillars with the optional tweeters SOLD Autozone Platinum Sealed Battery Brand new WITH Relocation Kit 18 Feet of wire Terminals Distribution Block. Brand new H@R Lowering Springs SOLD OEM Clutch Master and Slave A/C Compressor S14 5 Lug Front wheel hubs aftermarket OEM Steering wheel no airbag Manual Crankshaft KA24DE needs to be resurfaced Power Steering Pump SOLD Alternator Distributor NGK Wires Rebuilt Fuel Injectors O-rings Filters and Pintle caps x16 SOLD Pressure plate 2x Flywheel 1x Flywheel and Pressure plate bolts SOLD AT Transmission Dust Shield ABS System OEM Intake Timing guide chains and sprockets 4-1 Header EGR stuff S14 top mount turbo manifold with bolts and gaskets BRAND NEW S14 MOOG Front Lower Ball Joints x2 New SOLD Mobil 1 Oil filters x8 SOLD Traxxas t-maxx model 4910 Nitro 4WD 2.5 Engine race truck. Tons of extras parts tools fuel. SOLD Monster Fridge Centurion 3250 watt generator SOLD Engine Hoist Available for Pickup SOLD Engine Stand SOLD 3 Ton Low Profile Jack Available for Pickup SOLD 3 Ton Jack Stands x2 Available for Pickup SOLD Angle Grinder Polisher All parts are from a 1995 Nissan 240sx SE 5 Speed. If you don't see a part my 1995 was complete ASK for a part. Call or text for questions and prices 602-577-3457 Andre. Last edited by UkCobra; 09-04-2015 at 12:15 PM.. |
