03-23-2008, 04:47 PM | #1 |
need bolt sizes
i tried searching and found some bolt sizes i need but cant find the following: CAS bolt size, theres two, coilpack bolt, power steering bracket theres 3, thermostat housing also 3. Just need to know what size so i can go to napa or home depot and get some. Thanks in advance.
03-23-2008, 06:45 PM | #2 |
No Limit Soldier.
Power steering:M6x1.0, 10mm head.
Coilpack:M6x1.0, 10mm head. Power steering bracket: 14mm Head I believe. unknown thread pitch. Thermostat housing.: 10mm head. Unknown thread pitch. Hope this little helps.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
03-23-2008, 07:57 PM | #3 |
Rule of thumb with Nissan hardware:
8mm head = M5x.8 10mm head = M6x1.0 12mm head = M8x1.25 14mm head = M10x1.25 17mm head = M12x1.25 19mm head = M14x1.25 Other than the bellhousing bolts which are mainly M10x1.5 that's 95% of the engine, suspension, and chassis bolts/nuts you'll find on an S13 or S14.
03-23-2008, 09:07 PM | #4 | |
No Limit Soldier.
03-23-2008, 09:37 PM | #5 |
Yup, excellent information. As always RDM, you are full of good info.
"Genius may have its limitations, but stupidity is not similarly handicapped." |
05-28-2008, 02:08 AM | #7 |
Admin and/or Moderators.....Ross's post in this thread if not this thread needs to be archived or stickied.
Do need the Factory Service Manual? Click here. |
