#2912 |
#2914 | |
...Electrical starts on pdf page 672 but pdf pages 798 and on will help you visually. |
#2915 |
Banned from the Marketplace
hey i jusst bought some Battles for my coupe now i just wanted to know if i only need the 5 lug hub to attach it to my stock spindle or do i need other items? please lmk. thanks
#2916 |
![]() Join Date: Aug 2009
![]() Feedback Score: 14 reviews
ok so i blew my single cam about 3weeks ago...when it was still running the oil light would flicker at idle but go away when i stepped on the gas...so i got a new motor with a slight rebuild but i am using the same oil pump and sending unit..and its doing it again!!only at idle and goes away with acceleration...i checked out the pump and it seemed fine..so do u guys think its the pressure switch??please help=]
#2917 | |
![]() Join Date: Jul 2009
![]() or the holes on the bottom of the runners? and if the butterflies are removed are the hoses needed as pictured? ![]() |
#2918 | ||
Can't that track the coil? Also I know you're suppose to pull the fuse for the fuel pump but what about the fuel that's already at the rail? Quote:
Have you checked your oil pressure?
Almost there. |
#2919 |
i have not..how do i?everytime i remove the valve cover there is plenty of oil up there..but something can still be wrong i geuss..so any tips to check the pressure?
#2920 |
![]() Join Date: Sep 2010
ECU location
Im not sure if there is a thread for this ive typed ecu location on search and cant get anything also im sorry if its on this thread couldnt read all pages but yes im looking for the ECU on a 91 S13 all i know is that its on the passenger side also if possible not much to ask can someone post vids or pics to remove it and install also a pic of location it would be very helpful BTW im new at this sorry for the inconvience
#2921 | |||
![]() Join Date: Dec 2003
If you dont want air going in between the runners (which would cause turbulence, bad thing) you would need to weld every one of those holes Quote:
Dude its under the kick panel on the passengers side under the glove box. If you cant figure it out from there for yourself then you dont need to be working on a car.
![]() **CoUpe LOve** Member #00 |
#2922 |
91 coupe 5sp swap kad, supposedly 85k on swapped motor/trans from a 95. Idles high usually after its warm. Goes up to 1800 almost 2 rpms and drops to 1k-ish for sec then to normal? Also when accelerating past 4k rpms a bit of white smoke comes out the back. Anything would be appreciated.
#2923 |
I just bent the PISS out of one of my 18x9.5" KMC Hotwheels 68's. Its repairable, but im looking online where I can buy just (1) replacement. KMC's website sucks. Anyone have any idea where i can get just one?
#2924 | |
You have to remove the oil pressure switch next to the oil filter and install an oil pressure gauge there to read the pressure. Refer to your car's year FSM for the specifics.
Almost there. |
#2926 |
Anyone know any site where i can buy HKS EVC 6 components? I have the controller and the solenoid. Im missing the harnesses.
Originally Posted by EDaciouSX You should fix your opor grammar. |
#2928 |
From what I've seen in the past if a battery as anything about 10 and maybe lower I can remember exact numbers something will work brake lights or something but around 11 it can start having trouble starting a car. If you have 12 something should be working.
#2929 | ||
Anyone? ... |
#2930 |
I have an SR swap in my car (96 Zenki), old owner disconnected the sensor because he said it was reading double mph due to the fact that the speed sensor was for a kph speedometer. I was told I could swap over any 95-98 speed sensor from a KA with minimal modifications, is this true?
#2931 | |
#2932 |
#2935 |
![]() Join Date: Oct 2009
![]() Feedback Score: 11 reviews
anyone know if these wheels:
03 Deep Dish Machined/Anthracite Nitto Staggered Wheel and Tire Package will fit over brembo calipers? my 350z coupe wheels fit over them but the spoke design is a lot different. thats what i'm worried about the most is that the spokes will clear. ![]() ![]() thanks |
#2939 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
quoted from your original thread
Slip Gypsies Blog Quote:
