09-24-2010, 08:46 AM | #2851 |
My mechanic aligned my car on a Hunter alignment rack, and the results were okay, but slightly inconsistent. He told me I need RUCA's and a front camber kit to adjust camber so its even on both sides. The rear is the main offender. So I bought some SPL RUCA's, and I was wondering..
A) Should I wait to install them until right before going back for an alignment? B) If I decide to install them now, can I simply hold up the stock ones to the new ones, and use that as a basis of measurement for length? In my mind this would allow me to install them now, without affecting the current alignment. C) Are there camber plates available for strut/spring combo's, or do I need to use the camber bolt kit for the front? Car is an s14 by the way. |
09-24-2010, 09:11 AM | #2854 |
09-24-2010, 01:52 PM | #2856 | |
-Brandon |
09-24-2010, 02:18 PM | #2858 | |
[QUOTE=driftnuts
hey guys i need help here i did a clutch master and clutch slave on a friends car. He still has barely any pressure at all. Know what it could be? I tightened everything even the bleeder valve on the slave cylinder is tight. OH and its really hard to put in gear![/QUOTE] Quote:
09-24-2010, 03:21 PM | #2859 | |
B) Yes, for the most pat C) Camber bolt is cheaper and easier, but there are companies that make camber plates but you may need to get smaller (dia.) front springs.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
09-24-2010, 09:17 PM | #2861 |
so today i did a 3rd gear pull (i rarely get on my car but like to open it up every now and then) roughly 4000rpm when i downshifted to 3rd hit full boost and around 6000-6500rpm i was completely engulfed in smoke, smelled kinda like oil, checked the turbo on the conpressor side little to no oil residue found. checked hot pipe same thing, motor was rebuilt roughly 6000k miles/1 year ago, any ideas on what it could be? i'm thinking it could be the valve cover/spark plug gasket, hoping its not a piston ring but can anyone give me some insight or an opinion on what it could be and how to check it if it is a bad piston ring? my setup as far as what i think is important to know - redtop sr bc stroker kit, 262 cams, valve spring retainers, arp head studs cometic head gasket acl bearings gt2871r
edit please pm me!! |
09-25-2010, 01:35 AM | #2862 |
What is Rodknock and what causes it?
Is Rodknock fixable? If so how??
Do you have to entirely fix the engine or whatever? thanks Last edited by IrvinAmbil; 09-25-2010 at 01:46 AM.. Reason: Found answer to my previous question |
09-25-2010, 10:06 AM | #2863 | ||
09-25-2010, 01:05 PM | #2864 |
have you guys ever read the last pages of all the forums? The last page on chat has alot of wierd stuff lol, its pretty cool. Kinda like a time capsule
street dancer. GLEAM |
09-25-2010, 02:19 PM | #2865 |
I thought I saw some where before that the KA was turbo charged form factory at one point now I cant find anything saying yes or no can some on give me a straight answer please and thank you.
09-25-2010, 02:47 PM | #2866 |
NO KA was ever turboed from the factory not even JDM ones.
There were High Compression Single cams randomly over here but thats it. I believe a supercharged V6 was offered in some of the same trucks that the KA came in but no supercharged KAs either
09-25-2010, 03:09 PM | #2867 |
My clutch has no feedback anymore and it wont shift into gears. I checked and there is fluid but it is dirty. how do i figure out which to replace, the slave cylinder or the master, and can i do it without special tools? Also, I dont have to mess with the master brake cylinder at all right?
09-25-2010, 03:16 PM | #2868 |
Replace both master and slave. About $30 for both at most parts stores. If you still have issues its going to be clutch/TO bearing related.
Leave brake master alone.
09-25-2010, 03:44 PM | #2870 |
awesome, thanks! do i have to do anything special after i throw them in or can i just fill it up and drive? this small questions thread is great, i hope more people start using this instead of posting on answer questions in new threads.
09-25-2010, 03:57 PM | #2871 |
I have another small question I need help with.
For some reason my headlights are stuck up. When I try to put them down manually they go down then pop back up again automatically. I'm certain the fuses are fine, the motor is fine, obviously because it's working automatically. It's just not going down when I turn the headlights off. Anyone have a clue why?
'89 Coupe |
09-25-2010, 03:58 PM | #2872 |
did you push the button on the left side of the steering wheel which keeps the headlights up after you turn them off?
09-25-2010, 04:04 PM | #2873 | ||
Anyway yeah replace them, you should remove the bleeder block at the same time if you have already done so. Bleed the system. tighten everything up and top it off if needed, then drive. Quote:
09-25-2010, 04:11 PM | #2874 |
I'm running 8mm spacers in the front of my S14
Front inner fender linings removed, and hammered/rolled in front I tried to switch to 10mm spacers in the front this morning, and suddenly I'm rubbing tire to fender under regular braking, only on the driver side. It's wierd because it's only my driver's side, not passenger I switched back to my 8mm spacers and no problems again. Which part of the fender do I need to roll/hammer more to stop the tire rubbing under regular braking? Front of fender? Rear of fender? Will rubbing occur under turns? Thanks in advance, peace.
268generation.com -United for His Renown- |
09-25-2010, 04:50 PM | #2876 |
I don't think it's the wiring harness, because my S14 is green, and I put touchup paint on the underside of front fenders after the hammering/rolling (Had some very small paint cracks in the inner metal lip of front fenders)
After driving for 10 minutes with my 10mm spacers, the driver's side tire has some green paint on the sidewall of the tire. Wiring harness has been completely tucked and ziptied up to as close as the body as possible. I only rub the harness when I do full lock left turns (usually when I exit my garage or pull into parking spots). This is kinda strange to me because I'm not super slammed. Here are some pictures of my front driver's side fender setup. Front tire is 225/45/17 with +17 offset -8mm = +9 Edit: hmm I checked again this morning, and I have less than 2 fingergap's worth of space from fender to tire, so I guess this is why even with the extra 2mm it's rubbing.
268generation.com -United for His Renown- Last edited by EndLeSS8; 09-26-2010 at 01:14 PM.. |
09-25-2010, 07:08 PM | #2878 |
how good is the isis radiator quality-wise? it says its comparable to koyo, but obviously they're going to talk up their own product.
i'm asking because my radiator is leaking and i need a new one. |
09-25-2010, 09:28 PM | #2880 |
me again. a question about the butterflies on an s13 KA. I took mines out cuz i plan on boosting it soon. Whats the consequence if you dont weld those holes shut? will it cause too much air turbulence for each cylinder or what?
