#2731 |
![]() Join Date: Jun 2010
Currently I am unable to go to my S14 but does anyone know the length from the hub to the fenders in the rear?
Pretty sure its 5.15in but not 100% sure. Would be great if someone can look. Working on a calculator for wheel size for the S14 and if anyone has the info for S13, could do that too. thank you.
S14 KA NA two cylinders, 75whp limper |
#2733 |
So I have been searching for a good fitment and function for front wheels, for drifting.
I have been looking to upgrade my stock 15's I would like more grip and tire up front and something that looks a little better as well. My eye is on the xxr 527 I know everyone has these but they are pretty cheap and they don't really look that bad. The size I was looking at was 17x8.25 +25 I would like the offset at about +10 for these wheels but I have yet to find them. I am also running this setup at the moment if that makes a difference: PBM coils s14 FLCA s13 modded knuckles tein inner tie rods SPL tie rod ends So my question is how well will these fit and should I change my route for a better front wheel size for drifting? Sorry for the noobness I am researching as I go along. |
#2735 | |
That sounds like a horrible size. At least go 9" wide on a 17" rim - at least! If you're only going 8" wide, then you can do 16x8 rota grid offroad in et+20 or et +10.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#2736 | |
#2737 | |
It will probably require a 15mm spacer with approximately 3deg of negative camber.
#2738 |
![]() Join Date: Dec 2006
Just picked it up, How do I get this to fit on my R32???
lol ![]() ![]()
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#2740 |
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
Forgeline has conversion kits but its gonna cost major$$$$
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
#2742 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
Cons? Good luck turning and say good bye to full lock with stock inner fenders. Tubs or it will never happen. Camber and thin tires will not help you out either.
Pro's? There are none, 10" is the widest you will ever need or want to run on a S-chassis. Hacking and making more space isn't ideal and I don't see why people purposely do it. |
#2743 | |||
Man w/ CTSV & a Car Seat
#2744 |
haha yeah its a Monolug so cant really do anything else with it. Thought it would be cool for the Man cave
#2746 |
![]() Join Date: Mar 2009
I have 18x10+13 wheels. I usually run 225/40/18's but got some 235/40's for cheap. How much of a difference will there be? Will I need to totally change my setup or will it not change much? This is on the rear of my S13 coupe.
IG: slideonkranze |
#2748 |
![]() Join Date: Feb 2012
Roll fenders at the least. Maybe a pull (optional, depends on tire size as well).
ACE マジック HEART |
#2749 |
![]() Join Date: May 2013
What tire size would be good for a r32 gts-t? I will be putting these on my s13.
specs: diameter = 16" bolt pattern = 5x114.3mm offset = +40 width = 6.5" center bore = 66.1mm |
#2750 |
Trader Rating: (38)
What type of fitment are you looking for? Your choices are virtually endless depending on what you want out of your fitment.
If you're planning on lowering the car and don't want that battle ship look: 30mm. If you're on stock strut style, 15mm for the fronts, 17-20mm in the rear. If you have money for better sized wheels for the S13, ditch the R32 wheels. |
#2752 | |
#2753 |
Trader Rating: (38)
Oh shoot, I just realized your question wasn't about spacers but about tire size. I thought you were looking for spacer size. My bad lol
Well, stock sizing for S14 wheels are about the same as R32 wheels like Flip mentioned in his post so that would be 195/55/16 (I believe or 205/50/16) so I would follow that. If you want to be relatively low, you'll need to not run stock balloon sizes. Decreasing the sidewall profile works but 16" just suck period. You may as well go with 17's, better selection for tires. But anyway, back to my initial post, because the sizing is similar to S14 SE wheels, if you plan on going low, you will need spacers for which you can refer back to my initial post. |
#2754 |
Ended up getting Z32 wheels over the Gts-t wheels because the guy didn't respond to me. Anyways these are way cleaner the guy powder coated a nice grayish color on all 4 of them and I bought them for $150!
I have a question though the tire size on the rims are 225/50R16. Are they going to look too big on my s13? I'm riding with stock coils. Should I drop down to maybe 205? Thanks |
#2755 | |
#2757 |
That's nearly impossible to answer. Way too many variables.
ACE マジック HEART |
