#2731 |
sorry for this non nissan post but just wanted to share job i just finished friends CRX fully built B20 vtec turbo i did the intercooler mounting brackets, charge pipes with bov flange, and downpipe so far possibly more in near future.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() thanks for looking! love this thread keep up the good work guys ![]()
http://skywalkerindustrial.com |
#2733 | |
![]() Join Date: Oct 2006
Especially when you're cutting stainless all day..... Thins like 1.5'' thick solid SS round stock.. Fun times...
I have been tempted to try a dry cut blade for shits and giggles.. It's probably not suited well for SS. Whatever.. SS can go fuck it's couch... I had band saw blade that was "tolerable" on SS... Worked better-ish... Had a decent life. I can't remember for the life of me, who made it... My next investment will be to fund the development of a real working light sabre.. Then SS can eat shit and die.. |
#2735 |
#2736 |
What type of blade are you using in the bandsaw? 32tooth HHS? I guess I'll give that another go with a new blade next time.
Nickel sucks, just work hardens then its like cutting through the wall of china with a chissle. |
#2737 |
![]() Join Date: Feb 2007
![]() Feedback Score: 9 reviews
we use a cold saw. have you guy's gave that a shot yet
http://www.youtube.com/watch?v=QQz9x...eature=related YouTube - Makita LC1230 TCT Metal Cutting Chop Saw - great demo and review
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
#2738 | |
32t seems a bit fine, maybe that's your problem, it's like trying to file the tubing at that pitch in my opinion. i guess you could run 24 (or 20-24) as that seems to be the rule of thumb but the 10-14 works for me, i just pay attention to the chips so i can adjust feed or blade speed |
#2740 | |
The biggest issue is heat, there is a lot of nickel in 304 stainless and the hotter it gets the harder it gets, hence the issue with the chop saw. Its also much stronger than most band saw blades to begin with so I just loose teeth no matter what. I'm really interested to see if there are blades/wheels that can cut through stainless with out much issue. The only solution I've found is a Tungsten Carbide blade in a hack saw and thats not much of one really. |
#2741 |
Circular Saw Blades for Slugger and Evolution Saws at Van Sant Enterprises, Inc.
There you go.. Cold cut blades.. Some made specifically for stainless steel... Not cheap. But from the videos I've seen. They work effortlessly. Without creating enough heat to work harden it.. |
#2742 | |
i use a cold saw for everything.. the best saw you can own.
#2744 | |
we did at one point for a all stainless hand rail for this high end house. cut over 1000 cuts of 2'' od tubing with the makita cold saw.
#2745 |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
I have a Dake horizontal band saw that I have used for cutting everything and it works great. On the other hand we have a Dake automatic cold saw at work and that thing is fucking amazing! Although we dont use it to cut stainless everything else is a breeze. If and when I move out on my own a cold saw will be the first or second investment I make.
#2747 | |
Sadly I dont plan on doing much stainless and $145 is way to expensive ![]() |
#2749 | |
#2750 | |
Which bendtech software do you use and why. I was looking at them for a while and could not decide if they would be helpful to me. I mostly build roll cages |
#2751 |
I have Bendtech EZ, the cheapest one. You punch in a few measurements from inside the car and it will show you a 3D model of the bar and where to bend it and how much. Also tells you the length your piece will be. Its really helpful.
#2752 | |
How do you know where to take the measurements from |
#2753 | |
watch both of them... 15 times each... YouTube - 1 of 2 bend-tech assembly demonstration |
#2757 |
![]() Join Date: Dec 2002
Today I build another Blu808 Beef Supreme SR top mount manifold for an sr ae86. Sch 10 t304 stainless FTW.
Will be cleaning and welding it up tomorrow. ![]()
#2758 |
#2759 | |
BROWN! ![]()
#2760 |
