09-09-2010, 08:47 PM | #2731 | |
tuioewytuiweuriowefg
Nothing says racecar like a stock car with no interior. |
09-09-2010, 09:19 PM | #2732 |
Can someone lead me to the dude that does/did that custom hydro-dipping stuff.
pretty sure he did that set of jlines with the corny 100 doller lips or whatever. they were green/black. he had like a ls1 s14. was red or something. just cant quite remember his user name. help is appreciated
@pwrmves14 |
09-09-2010, 09:40 PM | #2733 |
Trader Rating: (53)
Feedback Score: 53 reviews
i could have sworn that i saw an install thread for the Kognition S14 sunroof delete somewhere on this forum. i have run numerous searches and it hasnt turned up. am i just delusional or does this thread really exist? anyone have a URL?
09-09-2010, 09:54 PM | #2734 |
Assuming the KA sensor fits in the RB, it makes sense to match the sensor to the gauge.
09-09-2010, 10:04 PM | #2735 | |
http://zilvia.net/f/chat/213929-you-dont-have.html
09-10-2010, 06:14 AM | #2737 | |
@pwrmves14 |
09-10-2010, 10:52 AM | #2738 |
If I remember correctly, that's the AIV. It directs some air into the exhaust to help the cat burn off excess fuel.
09-10-2010, 11:11 AM | #2739 |
Is Florida an easy state to register Japanese cars in?
Or easier than CA? If you know anything about registering an s15 in Florida or someone who might know please pm me or post in here if your ok with that. Sent from my iPhone using Tapatalk
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
09-10-2010, 11:47 AM | #2740 |
Anyone out there can show me a picture or link on how the bumper support bolts look like???
I believe it is a bolt and nut on both side. If anyone can help me out I will appriecate it thank you..
91 S13 Ka-t |
09-10-2010, 06:52 PM | #2742 | |
unfortunately this is pulled from nico...but looks to be true non the less. Front-End Installation Guide: S13 – NICO Club this is where it was pulled from. |
09-12-2010, 04:50 PM | #2745 | ||
09-12-2010, 05:37 PM | #2747 |
I think my power steering pump is going bad. I have to keep filling it up with fluid and even then it doesn't perform like it use to. After about 5-10 minutes of driving when I make right turns there's a loud wailing/whining sound that seems to come from the pump. From what I can tell none of the lines are leaking so I figured maybe air was in the system so I jacked the front up turned the car on and turned the wheel all the way left then right about 10 times. To no avail. Is this the proper bleeding procedure? Also, if my pump is dying why does it only wail when I more the steering wheel to the right(even just slightly)?
Also, my right dust boot on the rack is torn in half and I saw some fluid there. Is a little fluid normal or does this mean its bad as well? I was cleaning the underside of my car today and was scraping off some of the grime that had collected above the crossmember just below the rack and this fell out. Where does it go to?
Almost there. |
09-12-2010, 07:59 PM | #2748 |
wassup guys! i need an AC compressor for my 97 kouki. Does s13 or zenki compressor fits on the KOUKI? or is it jst the kouki compressor?! PM would b helpful! thanks
09-12-2010, 10:47 PM | #2750 |
4th small fitting/hole in Master Cyl. What is it? Does is it normally saposed to be plugged?
Heres a pic for reference. The small hole that looks plugged between the front and rear ports. I just picked up a master that has this so im wondering what I need to do with it or were I can get a plug for it. THANKS! |
09-13-2010, 10:52 AM | #2752 |
I wouldn't think you would need spacers unless PBM coils are especially girthy.
09-13-2010, 02:40 PM | #2753 |
is it true that for the ka24de the intake and exhaust valve seals are the same? and the sr20det exhaust seals = ka24de seals?
http://www.nissanroadracing.com/ |
09-13-2010, 10:06 PM | #2754 |
Trader Rating: (18)
Feedback Score: 18 reviews
Im planning to do a 5speed conversion.
What is a clutch fork pivot ball and do I need it in my conversion? If so, is it necessary or recommended to buy a new one? Thanks. |
09-13-2010, 10:19 PM | #2755 |
^^No. It is part of the 5 speed transmission. Only purchase of it is missing. No need to replace, unless you will be using an aftermarket pressure plate with a very high clutch capacity.
09-13-2010, 10:28 PM | #2756 | |
09-13-2010, 11:44 PM | #2757 |
??? whathappenedtothefewmembersofzilviawhoactuallyhave knowledge
09-14-2010, 03:38 AM | #2759 | |
did an oil change on my SR last week. as always i put in 4qts and its fine. this time i put in about 3.5 and check the dip run the car for a couple min and its at/little over H. any reason why it would be over H when i just put 3.5qt?
09-14-2010, 06:49 AM | #2760 |
I have a 3 piece rim that is leaking air from where the pieces bolt up. The bolts seem to be tightened. Will it be okay to seal it up from the inside with some sort of RTV sealant? Or is there another way to fix this? I'd hate to toss out the rim.
