#2731 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
What the fuck man? Lol
IG/TikTok-ThatS14_Z06guy |
#2732 | |
Trader Rating: (26)
Hell iirc there's a 440whp one. Just gotta remember who he is. Edit- I bought some more stuff for my bullet proof SR. Tomei type B dual valve springs and brand new Nissan VCT lifters. Now the only thing left stock in this engine is the rockers, crank and cam gears. Lol. Bought a WS harness to. With AEM AIT and MAP connections, w/o ABS also. She's gonna be ready and fired up by next month! Numbers soon!
IG/TikTok-ThatS14_Z06guy Last edited by EsChassisLove; 10-08-2012 at 11:35 AM.. |
#2738 |
![]() Join Date: Sep 2009
I am running the same setup, stock everything, 740cc and 300zx maf with all the necessary bolt ons, I am hoping for 280whp running 14-15 psi of boost after the tune (JWT)
#2740 |
![]() Join Date: Nov 2003
Seems like a little bit rich to me? Or do you guys all tune to 11 afr? I run mine at 11.7-12.1. Would you guys consider that unsafe? I'm also running meth water injection.
-Kyle ![]() |
#2741 | ||
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Torque curve looks good. Recommendation: 264 cams and external waste gate. Probably won't have to tune the afr after cams and proper boost control.
#2742 |
My mapper set it To 11.5 to be safe, slightly different afr reading to what he got.
yeah I don't think ill get much more out of it without cams. however the engine now has 140k on it so not sure how it will hold out. such a fun car to drive. Very easy to drift even with stock LSD |
#2745 | |
![]() You can run out of gas too if you don't pay attention to that either lol
-Kyle ![]() |
#2746 |
Running out of gas is not the same thing as running lean. Contrary to popular belief.
One will have you sitting on the side of the track crying! ![]()
#2747 |
Only 2871R I have used ..
S13 Engine- Forged Motor Stock Cam's 810-815cc Flow benched Apexi Injectors Ebay Exhaust mainifold MegaSquirt 2 "Extra Coded" ECU setup for 250KPa MAP Sensor and LC1 Wideband Target AFR trim control that Me and Bardabe 1/2 way Tuned .. Needs tuning past the 160KPa or 9PSI Made 286WHP on an AWD Dyno Dynamics that reads on the lower side .. Some how when we got to the dyno and started tuning we lost the clip on the wastegate so all it would boost is 9PSI @ 5600 or so RPM and above .. Made great power for only 9PSI .. Im impressed with the 2871 and the MS ECU .. |
#2748 |
![]() Join Date: Feb 2012
What do you guys think of this setup?
S14 SR20det Garret GT2871r 52T .64 A/R @20 psi with HKS actuator NGK #8 iridium plugs Tomei Exhaust Manifold and elbow Isis Downpipe, test pipe, and 3" straight pipe Greddy Intercooler and Oil Cooler Tomei 740cc Injectors and Fuel Pressure Regulator Z32 maf Tomei 1.5mm head gasket, head studs, rocker arm stopper Tomei 260/260 12mm cams, type A valve springs, valve guides, retainers, stock intake cam gear (to keep NVCS) and Tomei exhaust cam gear new oem rocker arms Greddy Intake Manifold and 70mm N15 throttle body Stock internals (maybe new piston rings and bearings) other supporting mods etc, etc.. Enthalpy ROM or Apexi PFC (Which would be better?) What numbers do you think I could expect with this? Would this be a good setup? Thanks. |
#2750 |
Cool, what about Nistune, are they any good? I'm kinda iffy about going full standalone since it will probably be a street car and I would rather just get a ROM tune. Aren't Nistune roms fully tune-able just like PFC's?
#2752 |
When do you guys recommend replacing the stock fuel press. regulator?
I'm currently running a S15 T28 with 550cc injectors tuned on Nistune making 286whp with the stock fpr, but I plan on upgrading to a 2871r soon and shooting for ~330hp ish. Should I upgrade to an adjustable fpr or sitck with the stock? Last edited by shifts13; 10-29-2012 at 07:16 PM.. |
#2754 | |
#2755 | |||
You can test your fpr by attaching a vacuum/pressure source to the vacuum port. Add some pressure to the nipple and make sure the FPR is able to hold that pressure (20psi) 30sec-1min all the same. Same thing with vacuum, you should be able to hold the FPR open for a minute and not allow the unit to close. Aside from physical leaks and such the stock unit should be capable of supporting the low hp levels you want to achieve. Quote:
SO for 450hp you should be on a fully rebuilt engine, no exceptions!<--for me ![]() side note:Have you every notice, the opinions of some members? It's like you can tell their political party preference, by the way they encourage a build or respond to a post. Just sayin'!
#2756 |
![]() Join Date: Jul 2005
I have seen the OEM fuel regulator fail around 330-350 horsepower. And the injectors go full open, the engine gets just enough to keep running yet lean enough to melt everything up. Just sayin'
#2757 |
Ahhhhhhhhhh yeah, so the fpr closing caused the injector to go static?
So priming the fuel system causes injectors to go static!? Actually no more of this my friend, I once saw, or super-street said.. nevermind
#2759 |
OK, I see what you did there!
That wouldn't be the fuel pressure regulators' fault though, or even the cause. I know some tuners aren't mechanics, but the best tuners are mechanics!
