09-27-2013, 05:41 AM | #2703 | |
Sikky Sway bar for me
09-27-2013, 03:38 PM | #2704 |
Anyone used a non-toyota transmission with the 2jz. I have seen a few 300zx and 350z adapter plate but anyone tried it. R154 are starting to be really expensive and I have a 300zx tranny laying in the garage.
09-28-2013, 10:03 AM | #2706 |
Pretty sure ive seen atleast one of those done... or maybe it was a Z33 trans that was done? You should do it and provide the community with a nice write-up!
09-28-2013, 11:11 AM | #2707 |
Trader Rating: (43)
Feedback Score: 43 reviews
Mike since ur running the sikky sway bar, is there any issues using the stealth custom fab tension front brace or the nismo unit? Thanks man.
fdrea |
09-28-2013, 11:22 AM | #2709 |
quick question on the heater hoses.
i want to use orange heater hoses, and not sure if there is a particular place to get them, but for the heater hoses does it matter where you hook them up? or does it not matter for inlet and outlet? the 1jz vvti has 2 openings, one on the exhaust side right next to the firewall heater hose inlets, and one on the intake side near the fuel rail kind of. does the one closest to the fire wall go on the top inlet on the firewall? let me know! thanks! |
09-28-2013, 03:53 PM | #2710 | |
09-29-2013, 06:44 PM | #2711 |
i was pretty set on running the VQ 6 speed for awhile, but you need to spend quite a bit of money on top of just the transmission to get it working in the car, not to mention the shifter assembly has to be cut and shortened, seemed like more of a headache and money pit then it was worth, i just went with a strengthened R154
09-30-2013, 06:45 AM | #2712 | |
09-30-2013, 04:36 PM | #2715 |
Thinking of making a build thread for my 2j journey
What I have so far R154 (mc goodies, and rebuild kit ordered) Myjzswap mount brackets /circuit sports solid mounts with custom spacers Custom 3.5in aluminum driveshaft (Savannah power train) w/spicer joints 97 Q45 diff -just ordered 30mins ago eBay twin scroll (getting rebraced and making it twin gate) 2 tial 38mm wastegates 4in downpipe/mid pipe for supra (gunna modify to fit) 4in straight pipe all the way back BW s366 with 90* housing Tial q 50mm bov 3in midmount hks intercooler/piping Tucked radiator ordered this morning I.D 1000 injectors A1000 fpr eBay rail dual 6an in /6an center return Ordering once I get the motor ordered coughflorantereacough Wiring specialties harness Aem ems v2 or pro efi if I can find a good deal. R154 bellhousing Act extreme clutch/flywheel Dual stealth 340 pumps 8an fuel feed line/6an return I'm sure I'm missing some stuff I need to get still or have. |
10-01-2013, 09:32 AM | #2719 |
6 Bolt axles are the way to go, I'm using a J30 Diff with the 6 Bolt axles, and 3.91 gears. should be just perfect. actually using the ABS Wheel speed sensor on the pumpkin to get the speedo signal for my cluster as well, saves you from having to use funky speed sensor on the R154
10-01-2013, 09:38 PM | #2721 |
I actually cant say for sure, but i Believe they all are, the only reason i'm using it is really for the 3.91 gears, i ditched the VLSD unit for a Tomei 2-Way one.
10-02-2013, 01:15 PM | #2722 | |
I purchased my xcessive brackets from frsport and I noticed they gave me the option of an s13 or s14 brackets. Where as other websites selling the xcessive brackets did not give you that option. So I called xcessive personally and they had said it does in fact matter if you purchase the s13 or s14 brackets due to proper fitment. So some of you with fitment issues might have the wrong option brackets? This is for 1jz into s13 btw. I have not test fitted mines yet but I wil let you guys know |
10-02-2013, 01:19 PM | #2723 | |
10-02-2013, 09:28 PM | #2724 |
Trader Rating: (18)
Feedback Score: 18 reviews
SO...as I was going to put on my oil pump and everything else, I noticed something.
It is small, but large enough to catch your fingernail if you run across it. I have already emailed the dealership I got them from about getting an exchange. Knowing most dealerships, they will most likely tell me to fck off. What are the chances of this thing leaking if I still try to use it? I just want to get a second opinion before I shell out another paycheck for an oil pump.
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
10-03-2013, 04:19 PM | #2726 |
Trader Rating: (18)
I'm going to be doing the same thing. I have blades from a sc300, mk4 tt, ka24 and a 7mgte, and clutches from a ls400, sc300, and sr20. im going to hopefully find out a combo that works the best.
10-03-2013, 07:52 PM | #2728 |
Personally if I couldnt get an exchange I would use the black toyota rtv, install front main, call it a day.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
10-03-2013, 11:17 PM | #2730 | |
